    Duet2 ethernet keeps pausing the print due to low voltage
    Duet Web Control
    error duet 2 ethernet pause resume low voltage
    • Jurisundefined
      Juris
      I have an issue where almost every time I start printing something, it pauses after like an hour, and when I press Resume, it just starts extracting the filament, and nothing else happens. I have to restart the printer for it to work. I have tried everything: I bought a new PSU, a voltage stabilizer, and a reserve power source in case of a power outage. Nothing changes. What could be the issue?
        Can you send M122 when you get these warnings and report the result?
        What exactly is the error you are seeing?
        Also please share your config.g
        Jurisundefined 1 Reply Last reply Reply Quote 1
        • Jurisundefined
          Juris @Phaedrux
          Hello @phaedrux! I am sorry for not responding, I was away.
          I ended up solving my problem.
          Turns out, that due to me not putting the cover on while using the printer in order to be able to debug, the board was just overheating causing it to shut down in order not to melt.
          Thank you for your courage to help me.
          -Cheers!
