    M915 Incorrect stall detection range for TMC2209 drivers
    Documentation
    • gloomyandyundefined
      gloomyandy
      I've just noticed that the M915 documentation has...
      Snnn Stall detection threshold (-64 to +63, values below -10 not recommended). Lower values make stall detection more sensitive. S3 is a good starting point for many motors.
      However boards that use the TMC2209 device actually accept a value that has a range of -128 to +127 see: https://github.com/Duet3D/RepRapFirmware/blob/3.4-dev/src/Movement/StepperDrivers/TMC22xx.cpp#L996
      You might also want to update the references to TMC2660 and TMC2130 to also include TMC2209 and TMC5160 (and possibly other devices if you have boards that include them).
      droftartsundefined 1 Reply Last reply Reply Quote 3
        droftarts administrators @gloomyandy
        @gloomyandy Thanks, updated. It was getting a bit long winded, so I moved the parameter description to a note.
        • droftartsundefined droftarts marked this topic as a question
        • droftartsundefined droftarts has marked this topic as solved
