Cannot update DWC using published instructions
Hello. My height map is not working. As per instructions, I navigated to the "system" tab in DWC and clicked "upload system files". I uploaded the zip file which is created when I download this repo: https://github.com/Duet3D/DuetWebControl. The name of the .zip file is DuetWebControl-Master.zip.
This did not have any effect.
I tried the backup method, deleting all files in the www folder and then copying the contents of DuetWebControl-Master to that folder, and now I cannot access DWC through my browser.
How can I update DWC and get my height map working?
@tylersuard said in Cannot update DWC using published instructions:
What do you mean by "working"?
That's not much to go on.
What version of firmware and DWC are you trying to use?
How are you trying to reach DWC?
What about your heightmap isn't working?
You should get the DWC files from here: https://github.com/Duet3D/DuetWebControl/releases
The version of DWC needs to match the version of your installed firmware.
