How to install Duet webControl?
Server is running but only white window when I connect to IP. Duet webControl 2.07 zip only has .gz files and folders. How do I install these on Duet2 ?
Insert the SD Card into a PC.
Rename www folder to www_old.
Create an new www folder and extract the files form the "Duet-Web-Control.zip" to that folder. -
@diy-o-sphere Thanks all installed succesfully. Now I am trying to get the magnetic filament sensor to work. After updating to 2.05.1 I just get:
Duet3D magnetic filament monitor on input 3, enabled, sensitivity 24.80mm/rev, allow 70% to 130%, check every 10.0mm, no data received.
Cables are fine all is rotating when filament is pulled but no data? Only one green flash after switch on. Any suggestions? -
