    Nema 17 steppenmotor
    • Nengerman
      Nengerman last edited by
      I have Nema stepper motors type
      Lengte: 47 mm
      Voltage: 3,3 V
      Houdkoppel: 5 kg-cm
      As diameter: 5 mm
      Stap hoek: 1,8 °
      Gewicht: 360 g
      Type: SL42S247A
      Nominale stroom: 2,5 A
      What is the best setting for these motors
      microstepping ?
      mA ?
        I suggest you set the current to 1500mA. If you get skipped steps you can increase it, but above about 2000mA the motors will run hot.
        The default microstepping of x16 with interpolation works well for most motors and printers.
