    Bowden coupler popping vs print speed/volume
    1
    1
    388
    • sungod3k
      sungod3k last edited by
      I have a realtivly beefy extrusion system for quick "draft" prints incl bondtec extruder und .6 solex3d nozzle. On my old system with a volcano I had implemented a 2nd bowden coupler because the e3d one would always pop out within the first minutes of printing.
      When I got the smart effector, I wanted to gave the standard bowden coupler a new try but now after a month od printing its starting to pop out again.
      I checked my extrusion volume for my current setup which is .45LH0.72LW50mm/s which gives me 16mm³/s which is higher that the usual 5-10mm³/s that "normal" printer do but still nowhere near the 20-30mm³/s what e3d and bondtec says their systems can handle.
      Therefore I just want to quickly survey what volumes you guys normally print at and if someone else is experiencing the same issues before I start designing a holder for an external coupler.
      Cheers
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
