    End of a print extruder reverses emptying all plastic.
    • mydayofplayundefined
      mydayofplay
      I'm having a problem after a print is finished it unloads all of my filament. I think the extruder is in reverse for about 300 mm to 500 mm worth of plastic.
      My gcode endcode is
      ;End GCode
      M104 S0 ;extruder heater off
      M140 S0 ;heated bed heater off (if you have it)
      G91 ;relative positioning
      G1 E-1 F300 ;retract the filament a bit before lifting the nozzle, to release some of the pressure
      G1 Z+0.5 E-5 X-20 Y-20 F{travel_speed} ;move Z up a bit and retract filament even more
      G28 ;move to endstops
      M84 ;steppers off
      G90 ;absolute positioning
        It's because you have sliced using absolute extrusion, and you have not include command M83 before your G1 E-1 command in your endcode. So insert M83 after the G91 command. Also insert M82 after the G90 command if you want to set the default back to absolute extrusion afterwards.
          mydayofplay
          OK the M83 and M82 commands strike again, What I really could use is cura doing this by default. Along with any other slicer.
          Thanks dc42
          • DjDemonDundefined
            DjDemonD
            I think it just cura. I use slic3r prusa edition and you just set use relative extrusion. Then all extrude gcodes are relative and you can retract whenever you want.
            www.precisionpiezo.co.uk
              mydayofplay
              I found out that with Cura if you save a profile it remembers start gcode and end gcode code. Even though it remembers your settings from everything else normally without making a profile.. Now I can close it turn off the computer come back to it and everything is like I left it!!
              So that solves that!
