    Filament sensor constantly throws errors
    Filament Monitor
    • TRATOONundefined
      TRATOON
      My Duet 3D Magnetic Filament Monitor says not enough movement 3 minutes into a print and after I resume it, it still happens. Here is how my filament sensor is configured.
      ; Filament Sensor
      M591 P3 C"e0stop" S1 D0 R10:190; filament monitor connected to E0 endstop
      M591 D0 ; display filament sensor parameters for extruder drive 0
      Here is m591
      m591 d0
      Duet3D rotating magnet filament monitor v4 on pin e0stop, enabled, sensitivity 28.80mm/rev, allow 10% to 190%, check printing moves every 3.0mm, version 4, mag 130 agc 77, measured sensitivity 26.76mm/rev, min 0% max 110% over 151.1mm
        droftarts administrators @TRATOON
        @tratoon For troubleshooting the magnetic filament sensor, see https://docs.duet3d.com/User_manual/Connecting_hardware/Sensors_filament#troubleshooting
        TRATOONundefined 1 Reply Last reply Reply Quote 0
        • TRATOONundefined
          TRATOON @droftarts
          @droftarts I have already taken a look, there is nothing in there that describes my issue, all my mag and agc values are fine
          infiniteloopundefined 1 Reply Last reply Reply Quote 0
          • infiniteloopundefined
            infiniteloop @TRATOON
            @tratoon Looks like you have a mechanical problem. @Lo-Fi has designed a housing which is better suited for FFM printers. The other option is to carefully file the filament path and the idler brackets until the hobbed assembly rotates smoothly.
            TRATOONundefined 1 Reply Last reply Reply Quote 1
            • TRATOONundefined
              TRATOON @infiniteloop
              @infiniteloop Thank you, I had already tried LoFi's design a few days ago, just had to file it down and tweak it a little, now it works like a charm.
              • TRATOONundefined TRATOON marked this topic as a question
              • TRATOONundefined TRATOON has marked this topic as solved
              • TRATOONundefined
                TRATOON @TRATOON
                This post is deleted!
                • TRATOONundefined
                  TRATOON @TRATOON
