    Duet Enthernet Bltouch
    • Altaez
      Altaez last edited by
      I do not have Bltouch. I did what it costs in the Wiki.
      When I specify the command M280 P3 S60 I1 shows z probe 1000. when I set M280 P3 S10 I1 gives an error
      https://www.youtube.com/watch?v=b4Xq69Zgj3o
      • Altaez
        https://www.youtube.com/watch?v=wLVdQA6E_GM
        • Altaez
          M111 S0 ; Debugging off
          G21 ; Work in millimetres
          M667 S1 ; Select CoreXY mode
          M208 X300 Y300 Z400 S0 ; Set axis maxima
          M574 Z0 S0 ; Define active low and unused microswitches
          M574 X1 Y1 S1 ; Define active high microswitches
          M307 H3 A-1 C-1 D-1
          M558 P5 X0 Y0 Z1 H5 F100 T2000
          G31 X0 Y0 Z0 P25
          ;M557 X15:285 Y15:285 S20 ; Define mesh grid
          M569 P0 S1 ; Drive 0 goes backwards
          M569 P1 S1 ; Drive 1 goes backwards
          M92 X80 Y80 Z405 E460 ; Set steps per mm
          M566 X900 Y900 Z12 E500 ; Set maximum instantaneous speed changes (mm/min)
          M203 X9000 Y9000 Z1200 E9000 ; Set maximum speeds (mm/min)
          M201 X700 Y700 Z250 E700 ; Set accelerations (mm/s^2)
          M906 X800 Y800 Z800 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
          M84 S30 ; Set idle timeout
          M143 S250 ; Set maximum heater temperature to 260C
          ;M305 P0 T10000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0
          ;M305 P1 T10000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 1
          ;M305 P1 T100000 B4725 C7.060000e-8 R4700 ; Set thermistor + ADC parameters for heater 1
          M305 P0 R4700 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
          ;M305 P1 R4700 C7.0600 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
          ;M305 P2 R4700 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
          ;M301 H1 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 0
          ;M301 H2 P10 I0.10 D100 T0.50 S1.0 ; PID settings for extruder 1
          M570 S120 ; Increase to allow extra heating time if needed
          M563 P0 D0 H1 F2 ; Define tool 0
          • Altaez
            can not help me?
