    Best method to seal carbon fibre tube
    Off Topic
    • A Former User?
      A Former User
      Hi all,
      I have cut down and put holes in a square carbon fibre tube to fit on my Voron, but I am concerned about the loose fibres finding their way into the linear rail that I will be attaching to it. I've washed it in soapy water and pushed damp tissues through it to remove as much carbon fibre dust as I can.
      Does anyone know the best way to seal the carbon away? I have an airbrush I could use. I was thinking of painting or spraying on some carbon fibre repair resin, but since I don't know exactly what resin was used to make the tube, I'm worried about flaking over time. It will be installed in an enclosure that can reach ~50°C, maybe a little higher in the future.
      Norderundefined 1 Reply Last reply Reply Quote 0
      • Norderundefined
        Norder @A Former User
        @threepwood
        Look for Epoxy Casting/Sealing Resin.
        Or use CA-Glue.
        How to Carbon Fiber Prep and Seal with CA Glue - Video
        How to cut Carbon Fiber Sheets and Carbon Fiber Parts and seal the cut edges - Video
        DDA5X... 0.9° Stepper... Linearrails... Duet 2 Wifi... PT100 Board... Duet IR-Probe... Dyze Pro Kit up to 500°C.. etc
        Thingiverse
