    Error: M956: Accelerometer not found
    • cosmowaveundefined
      cosmowave
      Hi all,
      yesterday i've installed an accelerometer (LIS3DH) on my Duet2Ethernet running RRF3.4.1
      When i try to collect datas with:
      G1 X-50 G4 S2 M956 P0 S1000 A0 G4 P10 G1 X50 F15000
      I get the message:
      The green LED on the accelerometer is on. And i have double checked my wiring.
      Is there something more i can check or measure?
      This is my config.g:
      config.g
      Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        dc42 administrators @cosmowave
        @cosmowave have you used M955 first to configure the accelerometer?
        cosmowaveundefined 1 Reply Last reply Reply Quote 0
          cosmowave @dc42
          @dc42 Yes, in my config.g
          M955 P0 C"spi.cs4+spi.cs3"							; create accelerometer
          I'm not sure if my cable is to long. I will try with a shorter one...
          dc42undefined 1 Reply Last reply Reply Quote 1
            @cosmowave try running that M955 command from the command line in case it reports an error.
            cosmowaveundefined 2 Replies Last reply Reply Quote 0
              cosmowave @dc42
              @dc42 Yes, it reports:
              Error: M955: Accelerometer not found on specified port
                cosmowave @dc42
                with a very short cable it works.
                I try to install the resistor like mentioned somewhere...
                  cosmowave @cosmowave
                  I've insalled a 560 Ohm resistor on the SDO Port. Now it works.
