    Connect Duetwifi via wifi to PC (no network)
    • Kilsdonk
      Kilsdonk last edited by
      Is there a way to connect Duet WiFi via WIFI direct to my PC without using a network.
        If your PC has WiFi then the easiest way at present is to configure your smartphone as a WiFi hotspot and connect the Duet and PC to it. Or you can use a mini router such as the WR710N, which also has an Ethernet connection you can use if your PC doesn't have WiFi.
        • Kilsdonk
          Working fine smartphone as WIFI hotspot. And is it possible without smartphone. I try to set up a WIFI hotspot on my macbook pro without succes.
            I hope to get the wifi access point functionality working on the Duet soon.
            • Kilsdonk
              Thanks,I will wait. Your DuetWifi and special the Smarteffector are working great. Z probing is fast and exact.
