    Invalid Height Map 3.4.2RC1 Delta
    Using Duet Controllers
    • garlicbreadundefined
      garlicbread
      I recently updated to version 3.4.2RC1 (I think from 3.2) on a Duet Wifi2
      I was going to go for 3.4.1 stable but I was a little worried about the mention of config.g disapearing in the change logs
      It looks like the web viewer has problems viewing the heightmap.csv file
      Contents of the file are:
      0:/sys/anycubic_delta/heightmap.csv
      RepRapFirmware height map file v2 generated at 2022-07-31 22:27, min error -0.626, max error 0.220, mean -0.190, deviation 0.234
      axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
      X,Y,-100.00,100.10,-100.00,100.10,110.00,20.00,20.00,11,11
            0,      0,      0, -0.598, -0.613, -0.585, -0.502, -0.383,      0,      0,      0
            0,      0, -0.626, -0.573, -0.608, -0.547, -0.464, -0.396, -0.415,      0,      0
            0, -0.554, -0.585, -0.532, -0.556, -0.486, -0.412, -0.375, -0.394, -0.346,      0
       -0.455, -0.452, -0.444, -0.396, -0.370, -0.372, -0.357, -0.322, -0.309, -0.315, -0.278
       -0.295, -0.347, -0.350, -0.306, -0.284, -0.329, -0.253, -0.271, -0.264, -0.234, -0.270
       -0.198, -0.125, -0.155, -0.189, -0.162, -0.127, -0.135, -0.189, -0.225, -0.238, -0.197
       -0.064, -0.113, -0.122, -0.107, -0.047, -0.045, -0.119, -0.138, -0.102, -0.118, -0.123
        0.075,  0.011,  0.058,  0.033,  0.047,  0.026, -0.043, -0.070, -0.025, -0.074, -0.041
            0,  0.152,  0.118,  0.065,  0.099,  0.051,  0.063,  0.011,  0.023,  0.044,      0
            0,      0,  0.158,  0.122,  0.112,  0.144,  0.100,  0.101,  0.114,      0,      0
            0,      0,      0,  0.220,  0.177,  0.201,  0.166,  0.165,      0,      0,      0
      I tried deleting the file then re-running G29 but it still seems to be the same.
      Maybe it's related to me using a delta, or perhaps because I'm using M505 P"anycubic_delta" I'm not sure
      The Statistics seems to show up ok though
      Statistics
      Number of points: 97
      Probing radius: 110 mm
      Probe area: 380.1 cm²
      Maximum deviations: -0.626 / 0.220 mm
      Mean error: -0.190 mm
      RMS error: 0.234 mm
      So I'm wondering if it could be a glitch in the web viewer part
        What version of DWC and Duet Firmware are you actually using?
        garlicbreadundefined 1 Reply Last reply Reply Quote 0
          garlicbread @Phaedrux
          @phaedrux https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.2rc1
          infiniteloopundefined 1 Reply Last reply Reply Quote 0
          • infiniteloopundefined
            infiniteloop @garlicbread
            @garlicbread Here’s your height map:
            Loaded it onto my Duet2 WiFi, cartesian, RRF 3.4.0.
            That means: your data are entirely valid, so, in theory, only the file format can be wrong.
            In order to visualise your height map, I pasted the contents from your post into a text editor (I’m on a Mac, so I took SimpleText) and converted it to plain text with UTF8 encoding, saved that and changed the file extension to .csv. Then, I copied the file into the /sys/ folder of the SD card … dunnit.
            To see whether the file format of your heightmap.csv is the culprit, follow the procedure I outlined above, then see if it woks.
              garlicbread
              Ok I think I was taking for granted that Duet2CombinedFirmware.bin also contained the web interface part.
              I'm noticing my web interface is on 3.2.2
              I can confirm that the Heightmap file was deleted then regenerated via G29 btw. But I'll try upping the web interface first.
                garlicbread
                Yep that fixed it my bad for forgetting to update the web interface
