    How would I connect a BL Touch to Toolboard 1LC v1.2?
    • TRATOONundefined
      TRATOON
      How would I connect a BL Touch to Toolboard 1LC v1.2? The documentation shows a 4 pin screw terminal, but there isn't one on mine (maybe that's an older version). And how would I configure the BL Touch in the RepRap Configuration Tool? (Just bought a Duet 3 so I'm making new firmware)
        dc42 administrators @TRATOON
        @tratoon it's the same as in the photo at https://docs.duet3d.com/Duet3D_hardware/Duet_3_family/Duet_3_Toolboard_1LC#connecting-peripherals except that the IO0 connector is now a 4-pin JST PH connector instead of a terminal block.
        • TRATOONundefined
          TRATOON
          @dc42 I notice that the Brown and Black wires go together in the screw terminal, how would I do this in the connector?
            @tratoon the wires are thin so you can crimp two of them into one pin.
            • TRATOONundefined TRATOON marked this topic as a question
            • TRATOONundefined TRATOON has marked this topic as solved
