    C290 With Duet lapse
    Third-party software
    1.0k
    • TRATOONundefined
      TRATOON
      Can someone quickly confirm that the Logitech C290 Will work with a rapsberry pi on a Duet 3 Running Duet Lapse?
      • stuartofmtundefined
        stuartofmt
        @tratoon said in C290 With Duet lapse:
        Logitech C290
        The short answer is "highly likely". I've tested both USB and Pi specific cameras with DuetLapse. DuetLapse directly supports USB cameras provided fswebcam is installed.
        You may also prefer to use:
        https://github.com/stuartofmt/videostream
        to connect to the camera (provides you with browser based viewing) and use DuetLapse to connect to the videostream output.
        I wrote both programs and can help get you going if you have trouble.
        TRATOONundefined 1 Reply Last reply Reply Quote 1
        • TRATOONundefined
          TRATOON @stuartofmt
          @stuartofmt Thank you for the reply, my C290 and Pi just arrived. Would it be possible to have a live feed of the camera in the DWC and have a timelapse recording during a print? If so, how would I do it?
          stuartofmtundefined 1 Reply Last reply Reply Quote 0
            stuartofmt @TRATOON
            @tratoon
            Yes - this is entirely possible.
            For the most part, the camera libraries in the Pi only allow one connection at a time. This is in part why I wrote videostream. It provides a http interface that can handle multiple connections to the video feed.
            I use it all the time with DuetLapse and a browser. The camera display in DWC can also be connected to videostream as the connection is the same as using a browser.
            It's all documented fairly comprehensively, if there is something that needs clarification, let me know.
            One thing I would say (if you are not overly familiar with the Pi etc.) - take it a step at a time.
            For example - make sure that the camera works using fswebcam first, then get videostream working and finally DuetLapse3.
            code7undefined TRATOONundefined 5 Replies Last reply Reply Quote 0
            • code7undefined
              code7 @stuartofmt
              @stuartofmt I am receiving this error message while testing to see if the USB camera will work with DuetLapse3. Does this response mean the camera is not compatible or might I be overlooking something else?
              pi@duet3:~/DuetLapse3 $ fswebcam image.jpg
              --- Opening /dev/video0...
              Trying source module v4l2...
              Error opening device: /dev/video0
              open: Permission denied
              Trying source module v4l1...
              Unable to find a source module that can read /dev/video0.
              Delta Printer Using a Duet 2 Wifi v1.04c, FW3.4.0beta2, Duet WiFi sever 1.26, Duet Web Control 3.3.0
                stuartofmt @code7
                @code7
                A couple of questions:
                What OS are you using?
                cat /etc/os-release
                The camera may not be /dev/video0.
                With the camera unplugged.
                1. What is the output of :
                v4l2-ctl --list-devices
                1. What is the output of:
                ls /dev/video*
                Plug in the camera and repeat the two commands above as well as:
                dmesg
                What new device showed up ?
                fswebcam can be directed to explicitly a particular camera with the form:
                fswebcam --device /dev/video[x] image.jpg
                Depending on how your Pi is set up there can be multiple logical camera's identified.
                You can also try these test programs:
                https://github.com/stuartofmt/Pi-Notes/blob/master/Resolution Testing.md
                stuartofmtundefined 1 Reply Last reply Reply Quote 1
                  stuartofmt @stuartofmt
                  @code7
                  Have you had success?
                  code7undefined 1 Reply Last reply Reply Quote 0
                  • code7undefined
                    code7 @stuartofmt
                    @stuartofmt Thanks for your recommendations. I actually found another camera that worked instead.
                    • TRATOONundefined
                      TRATOON @stuartofmt
                      @stuartofmt Hello, I got fswebcam to take a picture. However, I am having trouble with vidstream. I'm on Pi4 so I'm using libcam, I put in python3 ./videostream.py -port 8090 -pires "--width 800 --height 600"`. And I got a > on the console, I then went to pi'sip:8090/stream] and http://pi'sip:8090/stream, it says failed to open the page. Please help.
                      • TRATOONundefined
                        TRATOON @stuartofmt
                        @stuartofmt Just checked my OS, I' on Buster. So I tried installing opencv but the running setup.py bdist_wheel for opencv-contrib-python is taking a while
                        • TRATOONundefined
                          TRATOON
                          This post is deleted!
                          • TRATOONundefined
                            TRATOON @stuartofmt
                            @stuartofmt I installed DuetLapse and got videostream streaming, how do I tell duetlapse to start recording when I start a print, take a pic every 10 seconds, and when print is finished or canceled, compile it into a video?
                            So far I did
                            mkdir DuetLapse - or other directory of your choice
                            cd DuetLapse
                            wget https://github.com/stuartofmt/DuetLapse3/raw/main/DuetLapse3.py
                            chmod 744 DuetLapse3.py
                            • TRATOONundefined
                              TRATOON @stuartofmt
                              @stuartofmt Also, how do I have videostream autmatically run when pi starts?
                                stuartofmt @TRATOON
                                @tratoon
                                I have been offline for a couple of weeks.. have you tried following the examples in the documentation? If so, what issues are you seeing.
                                TRATOONundefined 2 Replies Last reply Reply Quote 0
                                • TRATOONundefined
                                  TRATOON @stuartofmt
                                  @stuartofmt every time I shut down and power the pi on, I have to send the nohup command to run video stream anyway to automate this.
                                  • TRATOONundefined
                                    TRATOON @stuartofmt
                                    @stuartofmt I will try to figure duet lapse 3 over weekend
                                      stuartofmt @TRATOON
                                      @tratoon
                                      In my view - the best way to control videostream at startup is with systemctl.
                                      There is an example unit file and instructions in the documentation.
                                      You don't need to run it with nohup.
                                      Give systemctl a go and if you have issues I can help.
                                      TRATOONundefined 1 Reply Last reply Reply Quote 0
                                      • TRATOONundefined
                                        TRATOON @stuartofmt
                                        @stuartofmt sudo -H -u pi python3 /home/pi/DuetLapse/DuetLapse3.py -duet 192.168.1.217 -seconds 20 -detect none -camera1 web -weburl1 http://192.168.1.217:8090/stream I have this line In rctest.local along with a line that starts videostream.
                                        In my DuetLapse/duet3/192-168-1-217 I have 2 folders: 603 & 1639 Both with JPEGS that give errors when I try opening something about it starts with some character. I also have a bunch of logs in there.
                                          stuartofmt @TRATOON
                                          Also - if you are having problems, its best to run the program from the command line and include -verbose. That way you will get a log file and be able to see if there are issues being reported on the console.
                                          When you view http://192.168.1.217:8090/stream from a browser, does it display ok?
                                          I cannot do much to help you without seeing the logfile (using -verbose). My guess is that there is an issue with ffmpeg.
                                          What output do you get from running:
                                          ffmpeg --version
