    File seems to crash the firmware (Maybe Line Endings?)
    Firmware installation
    • dgratundefined
      dgrat
      I noticed that the firmware/WebApp seems to crash if I upload and execute this file.
      Copying the content with Notepad++ into a new file seems to work.
      lin_adv.gcode
      dc42undefined chrishammundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @dgrat
        @dgrat the line ending shouldn't matter. Which board and firmware version are you using?
        dgratundefined 1 Reply Last reply Reply Quote 0
        • dgratundefined
          dgrat @dc42
          Board: Duet 2 WiFi (2WiFi)
          Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.1 (2022-06-01)
          Duet WiFi Server Version: 1.26
          • dgratundefined
            dgrat @dgrat
            @dgrat
            I think it might be the coding. I was piping the output of a python script with powershell. Maybe a coding check (warning) in the web-app or firmware would be beneficial.
              @dgrat yes, that file is UTF16 encoded. RRF only accepts UTF8 and plain ASCII.
              • chrishammundefined
                chrishamm administrators @dgrat
                @dgrat In SBC mode it may be possible to use UTF-16 files because the file readers should auto-determine the underlying encoding. I have not tested this yet, though.
                Duet software engineer
                • dgratundefined
                  dgrat @chrishamm
                  Do you think it makes sense to check encoding in the firmware and reject the file to avoid UB.
