blank white screen on paneldue 7i
i have a modix big-60 v3 and it has a paneldue i7 inside it. recently the panel started showing only a white screen and did not respond to any touch. i flashed the most recent firmware following the directions on the site but no dice. the erase button was never pressed although i pressed the reset button several times after the panel going white.
it does show up on a computer and flashing with bossa succeeds. any ideas on fixes/replacements would be appreciated. -
Have you taken it out of the casing to test?
What firmware file exactly did you flash?
