How to: storing the Z-offset automatically without using M500
If for whatever reason you want to store the Z-offset outside of the config.g file (in this example in a file named config_probe.g), here is the method I've found out to work quite well.
This method works for RepRapFirmware 3.4 and up, as we need to use the ability to write to a file using the echo command. It has been tested on 3.4.1
For more info, see https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#echo-command
The macro also allows you to automatically compensate for using of a known thickness shim, using the var probing_tool setting at the start of the macro.
Z-offset macro:
var probing_tool = 0.000 ; This allows you to compensate for whatever tool you use to measure the nozzle distance. ; It is set to 0.000 by default, you can set this to the thickness of the tool or paper you use for the Z-offset calibration ; A sheet of paper is on average 0.05 to 0.10mm thick. M291 S3 R"Heating up nozzle" P"Wait for the nozzle to reach printing temperatures" M568 P0 S215 ; set tool 0 (primary hotend) temperature to 215c T0 ; select tool 0 (primary hotend) M116 P0 H5 ; wait for temperature to reach within 5c of set temperature M300 S666 P666 ; beep M291 S3 R"Setting the Z-offset Height" P"Press OK to continue, or CANCEL to abort" G28 ; home all G29 S2 ; cancel mesh bed compensation M290 R0 S0 ; cancel baby stepping G90 ; absolute movements G1 Z10 G1 X100 Y100 F1800 G4 P0 M300 S1111 P666 ; beep M564 H1 S0 ; ignore axis limits M291 S2 R"Test Z Probe Trigger Height - Step 1" P"Place a paper sheet under the nozzle and raise the bed until slight friction can be noticed" Z1 ; G92 Z0 ; the nozzle should now be just touching the bed so set the logical Z position to match the physical Z position M300 S666 P666 ; beep G1 Z8 F300 ; insure Z position will allow for probing G4 P0 ; wait for the movement to stop M291 S2 R"Test Z Probe Trigger Height - Step 2" P"Please remove the paper sheet and wait for the bed-probing to begin" ; G30 S-1 ; probe the bed and report the Z probe trigger height M564 S1 H1 ; respect axis limits ;M291 S2 R"Test Z Probe Trigger Height - Step 3" P"Copy the reported height value on the G-Code console and paste it into the config_probe.g file" var Z_auto_offset = {sensors.probes[0].lastStopHeight+var.probing_tool} ; math to calculate the BLTouch offset echo >"0:/sys/config_probe.g" "G31 Z"^{var.Z_auto_offset} ; write the Z-offset to the config_probe.g file echo "the Z-offset has been stored in the config_probe.g file. The Z-offset is", var.Z_auto_offset, "mm" G4 P0 ; wait for the movement to stop G1 Z10 F300 ; Lift up the nozzle again so it's not pressed against the bed surface
config_probe.g :
G31 Z1.5
It's a fairly simple macro, but if there are any questions let me know
Any chance i can save the Z-offset directly in the "Config.override" file without deleting all the other settings instead of creating a new one?
Thanks a lot for your time. -
@Trojan3D If you change it to be >> instead of > on the echo, it adds data to the file instead of overwriting it
So in your case it would be:
echo >>"0:/sys/config-override.g" "G31 Z"^{var.Z_auto_offset} ; write the Z-offset to the config-override.g fileThis adds the value to the last line of the config-override.g, however you will see it become quite a mess over time, as the echo >> only adds another line
So after doing it ten times, you it would have the G31 Z value added ten times in a row, with the bottom one being the value you're trying to have.
That's why it's generating a separate file called config_probe.g in this example, and then you can load the Z-offset using a M98 P"config_probe.g" in your config.g and homing files
@ComedianTF2 That's great, thank you very much for your help!
New to duet and trying to figure out what's what here in my new Prusa Bear with Duet mini.
All the best and thank you again. -
@ComedianTF2 Hi, thanks for this macro, it's very handy. I've tried to use it but i think I'm having a problem with calling the config_probe.g file into config.g. I've used:
G31 K1 P500 X-28.2 Y-18.1 ; set Z probe trigger value offset
M98 P"0:/sys/config_probe.g" ; z probe trigger heightWhen I try to print, there isn't any z-offset. Am i doing this properly?
Thanks
@bluenavy I have it similar to you, so check that the config_probe.g is populated properly
G31 P500 X-22.5 Y38.9 ; BLTouch X and Y offset M98 P"config_probe.g" ; Load the Z-offset from the config_probe.g file
Then the config_probe.g file is this:
G31 Z2.688
And homing files also have the Z-offset loaded in there
; homeall.g ; called to home all axes M98 P"config_probe.g" ; Load BLTouch probe settings M280 P0 S60 I1 ; clear any probe errors G29 S2 ; cancel mesh bed compensation G91 ; relative positioning M913 X50 ; X axis 50% power G1 H2 Z5 F200 ; lift Z relative to current position G1 H1 X{(move.axes[0].max+5)*-1} Y{move.axes[1].max+5} F3000 ; move quickly to X and Y axis endstops and stop there (first pass) G1 H2 X5 Y-5 F600 ; go back a few mm G1 H1 X{(move.axes[0].max+5)*-1} Y{move.axes[1].max+5} F600 ; move slowly to X and Y axis endstops once more (second pass) M913 X100 ; X axis 100% power G90 ; absolute positioning G1 X{move.axes[0].min+2} Y{move.axes[1].min+2} F6000 ; move to front left G1 F600 ; reduce speed G30 ; home Z by probing the bed G29 S1 ; load heightmap
@ComedianTF2 Thanks!
