    Thermistor NTC 6K523, replacement
    • tanga2
      tanga2 last edited by
      Hi guys,
      I need replacement for this thermistor, values in table :
      https://drive.google.com/file/d/0Bxv5z9DWZ7ZwajNUbTRtVkN0TWs/view?usp=sharing
      If there is any exactly replacement, its enought same values 0celsius to 100 celsius from table.
      Thank YOU
      Matus
        That thermistor has an unusual resistance at 25C, so it's likely to be hard to find a good match. The closest I found was https://www.digikey.co.uk/product-detail/en/epcos-tdk/B57891M0682J000/495-3071-ND/652254.
        Can you adjust the firmware or the hardware that is used with it so as to accommodate a different thermistor?
