    Do I need to solder the 3.3v Jumper on the panel companion board
    PanelDue
    • ericsmith66
      ericsmith66 last edited by
      I have a question about the 7 inch Panel. I see reference here:
      https://miscsolutions.wordpress.com/paneldue/
      that I need to solder the 3.3v jumper on companion board if you have the 7 inch Panel. I just purchased the panel and the companion board from https://www.filastruder.com and I did non see mention of it there or on the base wiki.
      Is this correct?
      Thanks
      Eric Smith
        The link wire is only needed when using a very old PanelDue board. The version 3 board doesn't have a voltage selection jumper, it is set to 3.3V.
