    Store endstop status in a variable
    Gcode meta commands
    • jan12345undefined
      jan12345
      Is it possible to store the status of an endstop in a variable?
      My goal is to write something like this:
      var endstop_status = M119 X
      if endstop_status = TRIGGERED
          G1 .....
      else
          G1 .....
      Is it possible to base a condition on the status of an endstop?
      Nightowlundefined dc42undefined 2 Replies Last reply Reply Quote 0
      • Nightowlundefined
        Nightowl @jan12345
        @jan12345
        As far as I understand it yes, but you'll (probably) need to reference it from the Object Model.
        You can define variables within the config.g file , like I do here:
        ; Variables definition
        global savedSpindleSpeed = 0
        global PausePress = false
        But the status of the variable need to be set within the macro that calls it, i.e. in my pause.g file:
        ; pause.g
        M42 P8 S0								; pause/resume LED off
        set global.PausePress = !global.PausePress				; toggle the value from whatever it was before
        set global.savedSpindleSpeed = spindles[0].active			; sets the global variable
        echo "Spindle speed saved at ", {global.savedSpindleSpeed}, "RPM"	; shows saved spindle speed in the Console
        G1 Z{max(move.axes[2].userPosition+5,move.axes[2].max-5)} F2400		; move the Z axis to a safe height
        G0 X273.5 Y560								; move XY to a safe place
        M5
        Sorry, I'm not a techie, but I hope this helps.
        Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
        I'm still on my learning curve, so take everything I say with caution!
        RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
          dc42 administrators @jan12345
          @jan12345 said in Store endstop status in a variable:
          Yes:
          if sensors.endstops[0].triggered
              G1 ...
          else
              G1 ...
          No need to use a variable unless you want to save the triggered state to use later.
