    3.4.2rc3+ Duet Froze when logged into to webcontrol
    Beta Firmware
    • Adamfilipundefined
      Adamfilip
      Was running a 16hr job. on my custom Voron 2 style machine.
      I have a Duet 2 wifi with Duex5 expansion
      was printing fine, but hen I logged into to webcontrol in chrome to check on its progress it Duet froze and the job was lost
      Had to physically power off the printer and restart to get to be responsive.
      I have updated to RC3 since then. (was on RC2)
      M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.2rc3+ (2022-08-31 12:50:46) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 08DLM-996RU-N85T0-6JKF2-3SJ6Q-1AVVR
      Used output buffers: 1 of 26 (22 max)
      Static ram: 23860
      Dynamic ram: 75752 of which 40 recycled
      Never used RAM 12428, free system stack 182 words
      Tasks: NETWORK(ready,20.8%,137) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,78.2%,428) IDLE(ready,0.9%,30), total 100.0%
      Owned mutexes:
      Last reset 00:05:43 ago, cause: software
      Last software reset at 2022-09-02 09:29, reason: User, GCodes spinning, available RAM 7908, slot 1
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 33.1, current 33.5, max 35.5
      Supply voltage: min 24.0, current 24.2, max 24.3, under voltage events: 0, over voltage events: 0, power good: yes
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min n/a
      Driver 1: standstill, SG min n/a
      Driver 2: standstill, SG min n/a
      Driver 3: standstill, SG min n/a
      Driver 4: standstill, SG min n/a
      Driver 5: standstill, SG min n/a
      Driver 6: standstill, SG min n/a
      Driver 7: standstill, SG min n/a
      Driver 8: standstill, SG min n/a
      Driver 9: standstill, SG min n/a
      Driver 10:
      Driver 11:
      Date/time: 2022-09-04 14:33:36
      Slowest loop: 171.40ms; fastest: 0.18ms
      === Storage ===
      Free file entries: 9
      SD card longest read time 26.8ms, write time 68.5ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters 0 -1 -1 -1, chamber heaters 2 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === DueX ===
      Read count 1, 0.17 reads/min
      === Network ===
      Slowest loop: 1107.96ms; fastest: 0.00ms
      HTTP sessions: 1 of 8
      = WiFi =
      Network state is active
      WiFi firmware version 1.27beta1
      WiFi MAC address 84:0d:8e:b2:f8:6f
      WiFi Vcc 3.32, reset reason Turned on by main processor
      WiFi flash size 4194304, free heap 24328
      WiFi IP address 192.168.0.195
      WiFi signal strength -72dBm, mode 802.11n, reconnections 0, sleep mode modem
      Clock register 00002002
      • Phaedruxundefined Phaedrux moved this topic from General Discussion
        So is that M122 collected after the freeze? Or did you update firmware etc and then capture an M122?
        Adamfilipundefined 1 Reply Last reply Reply Quote 0
          Adamfilip @Phaedrux
          @phaedrux yes M122 was collected after restarting and updating. I realize perhaps not helpful.
            If it happens again on RC3+ please capture an M122 immediately and post it here.
