    Wifi module is not working
    Firmware installation
    • Gopiundefined
      Gopi
      I have updated my Duet 2 wifi firmware from 3.2 to 3.4.1 via DWC. But during the update process the wifi connection was lost. When I tried to connect it to YAT I could see that the firmware has been updated to 3.4.1. But when I tried to run M552 S0 it just returned ok. With M552 S1 it returned Turn off the current WiFi mode before selecting a new one.
      I tried to reflash the duet with M997 S1 but it returned Error: M997: File 0:/firmware/DuetWiFiServer.bin not found.
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.1 (2022-06-01 21:05:28) running on Duet WiFi 1.02 or later + DueX5
      Board ID: 0JD0M-9X6JA-JUNSN-6J9F4-3SN6L-9BN3T
      Used output buffers: 1 of 26 (11 max)
      Static ram: 23860
      Dynamic ram: 73864 of which 0 recycled
      Never used RAM 14356, free system stack 185 words
      Tasks: NETWORK(ready,7.4%,517) HEAT(notifyWait,0.0%,388) Move(notifyWait,0.0%,363) DUEX(notifyWait,0.0%,24) MAIN(running,92.6%,449) IDLE(ready,0.0%,30), total 100.0%
      Owned mutexes: USB(MAIN)
      Last reset 00:37:47 ago, cause: power up
      Last software reset details not available
      Error status: 0x00
      Step timer max interval 0
      MCU temperature: min 24.7, current 25.9, max 26.3
      Supply voltage: min 0.5, current 0.5, max 0.6, under voltage events: 0, over voltage events: 0, power good: no
      Events: 0 queued, 0 completed
      Driver 0: ok, SG min n/a
      Driver 1: ok, SG min n/a
      Driver 2: ok, SG min n/a
      Driver 3: ok, SG min n/a
      Driver 4: ok, SG min n/a
      Driver 5: ok, SG min n/a
      Driver 6: ok, SG min n/a
      Driver 7: ok, SG min n/a
      Driver 8: ok, SG min n/a
      Driver 9: ok, SG min n/a
      Driver 10:
      Driver 11:
      Slowest loop: 26.04ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.2ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty
      === DueX ===
      Read count 0, 0.00 reads/min
      === Network ===
      Slowest loop: 1.02ms; fastest: 0.00ms
      HTTP sessions: 0 of 8
      • WiFi -
        Network state is starting2
        WiFi module is disabled
        ok
      Couldn't find a solution to resolve this problem. Hope the experts on this platform help me to find a solution. Thanks for your time in advance.
      Please let me know if you need further information.
        jay_s_uk @Gopi
        @gopi please send
        M552 S0
        M997 S1
        M552 S1
        That should reflash the WiFi firmware and get you back up and running
        Gopiundefined 1 Reply Last reply Reply Quote 1
        • Gopiundefined
          Gopi @jay_s_uk
          @jay_s_uk M552 S0
          ok
          M997 S1
          ok
          M552 S1
          ok
            jay_s_uk @Gopi
            @gopi you'll need to place the latest wifi firmware version in the firmware folder on the SD card. it can be found here https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.1/DuetWiFiServer.bin
            then repeat the above
            • Gopiundefined
              Gopi
              The problem is partly resolved. Thanks to your help, wifi module is now connected. But I could not connect to access the DWC via IP address. It shows that the www files are missing. And I could not find these files in the internet. I have attached an image of my SD card. I am using e3D tool changer printer.
              TH![alt text](SD card.PNG image url)
                jay_s_uk @Gopi
                @gopi you should have a folder called www in the root of the sd card.
                extract the contents of this zip file https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.1/DuetWebControl-SD.zip into that folder
                Gopiundefined 1 Reply Last reply Reply Quote 2
                • Gopiundefined
                  Gopi @jay_s_uk
                  @jay_s_uk My module is connected and running. Thanks for the help.
