    Filament config.g reload at reset
    Duet Web Control
    • DK4YAundefined
      DK4YA
      Filament config.g
      Is there a way to use the preloaded filament, e.g. PETG loaded with load.g, which will run the appropriate config.g on next reboot. So that the filament settings for the loaded filament are also present again, e.g. M572 or similar?
      deckingmanundefined chrishammundefined 2 Replies Last reply Reply Quote 0
      • deckingmanundefined
        deckingman @DK4YA
        @dk4ya said in Filament config.g reload at reset:
        Filament config.g
        What I do is have filament specific settings as macros e.g.
        ; Settings for ABS
        M220 S100; set speed factor override percent to 100%
        M106 P0 X0.0; set maximum fan speed to 0%
        M207 S5.0 R0 F1800 T1800 ;set firmware retraction
        M572 D0 S0.10 ; set pressure advance coefficient
        M572 D1 S0.10
        M572 D2 S0.10
        M572 D3 S0.10
        M572 D4 S0.10
        M572 D5 S0.10
        These are stored in a folder with the macros folder called "Filaments" So the contents look like ........
        To load a particular set of filaments entails running the appropriate macro.
        e.g. M98 P"0:/macros/Filaments/ABS.g"
        So if you put that M98 at the end of config.g, it will run whenever config.g is loaded which is whenever the board is powered.
        DK4YAundefined 1 Reply Last reply Reply Quote 0
        • DK4YAundefined
          DK4YA @deckingman
          @deckingman
          Yes exactly, here I call up filament-specific settings. But after a restart the filament is still set to e.g. PETG but the settings are not loaded.
          So I ask if it is possible to automatically load the config file of the correspondingly loaded filament when starting?
          • OwenDundefined
            OwenD
            @dk4ya
            Try M703 at the end of /sys/config.g
            If there was a previously loaded filament it will run the corresponding /filaments/xxx/config.g
            Or you can check the object model for a loaded filament and use conditional code to parse that to whatever macro you want
            • chrishammundefined
              chrishamm administrators @DK4YA
              @dk4ya It is recommended to insert M703 in your tpost*.g so the loaded filament is automatically configured when you select a tool.
              Duet software engineer
              • DK4YAundefined
                DK4YA @chrishamm
                @chrishamm @deckmann,
                I thank you very much for this great hint.
