    Any idea why my mesh would be this off? Duet 3/smart effector
    • eddygaraundefined
      eddygara
      That there is my good old calibration mesh from this fairly new built machine, towers ans such seem to be at full square, and the system is brand new. I'm using the same config files from my other machines that run Duet WiFi,s and FSRs for probing.
        dc42 administrators @eddygara
        @eddygara did you run delta calibration first? My guess is that you didn't and the calibration is off.
        eddygaraundefined 1 Reply Last reply Reply Quote 0
        • eddygaraundefined
          eddygara @dc42
          @dc42 always 1st then mesh after wars. this is the result at the moment.
            @eddygara:
            1. What were the displayed results of delta calibration?
            2. Does running delta calibration a second time give significantly different results (from delta calibration)?
            3. Did you home the printer again before running mesh compensation? It's best not to, but it shouldn't make very much difference.
