    GOING FROM V6 TO REVO HOTEND
    Config Tool
    • Adam_Sw3undefined
      Adam_Sw3
      Good Afternoon All, I am using Duet 2 WiFi/Ethernet 2.03.
      I am switching from a V6 to a REVO hotend, installed, all wired up and it is showing a temperature of 2000*c. I have checked all wiring thoroughly to try and find the issue and cannot seem to locate what it is.
      Therefore I was wondering if it may be something I need to change in my firmware? Whether it is a new sensor type etc?
      Please see below my code:
      ;Hotend Heater
      M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 1 as thermistor on pin e0temp
      M950 H0 C"e0heat" T0 ; create nozzle heater 0 output on e0heat and map it to sensor 0
      M307 H0 B0 S1.00 ; disable bang-bang mode for heater 0 and set PWM limit
      M143 H0 S280 ; set temperature limit for heater 0 to 280C
      Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
      • Rushmere3Dundefined
        Rushmere3D @Adam_Sw3
        @adam_sw3 That's the correct sensor, a temp sensor showing 2000°c is I believe a wiring fault somewhere.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        Adam_Sw3undefined 1 Reply Last reply Reply Quote 0
        • Adam_Sw3undefined
          Adam_Sw3 @Rushmere3D
          @rushmere3d Hmmm, I will have to check through it again. Thank you!
