Stop Deploying Probe (Solved)
  • I recently upgraded to 1.19 from 1.18. When I run G32, my delta (DC42 large delta with smart effector) looks like it is deploying and retracting a mechanical probe even though I delete those lines from my bed.g file in /sys. Below are my config.g and bed.g files. Is there a possibility of a random bed.g file is being used to calibrate my delta?
    As always, thanks for your indispensable help and guidance,
    Greg
    ; Configuration file for Mini Kossel kit from Think3DPrint3D for testing Duet WiFi
    ; Communication and general
    M111 S0 ; Debug off
    M550 PRostockGPC ; Machine name and Netbios name (can be anything you like)
    M551 Preprap ; Machine password (used for FTP)
    ;*** If you have more than one Duet on your network, they must all have different MAC addresses, so change the last digits
    M552 P192.168.1.19 ; Machine IP address
    M553 P255.255.255.0
    M554 P192.168.1.2
    M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
    ;*** Wifi Networking
    M552 S0 ; Disable WiFi
    M552 S1 ; Enable WiFi
    M555 P2 ; Set output to look like Marlin
    M575 P1 B57600 S1 ; Comms parameters for PanelDue
    G21 ; Work in millimetres
    ; Axis and motor configuration
    M569 P4 S1 ; Drive 4 goes forwards
    M574 X2 Y2 Z2 S1 ; set endstop configuration (all endstops at high end, active high)
    ;*** The homed height is deliberately set too high in the following - you will adjust it during calibration
    M665 R140 L360.26 B130 H462 X0.00 Y0.00 Z0.00 ; set delta radius, diagonal rod length, printable radius and homed height
    M666 X0.00 Y0.00 Z0.00 ; put your endstop adjustments here, or let auto calibration find them
    M350 X16 Y16 E16 I1 ; Set 16x microstepping with interpolation
    M92 X200 Y200 Z200 ; Set axis steps/mm
    M906 X1000 Y1000 Z1000 E800 I60 ; Set motor currents (mA) and increase idle current to 60%
    M201 X1000 Y1000 Z1000 E1000 ; Accelerations (mm/s^2)
    M203 X20000 Y20000 Z20000 E3600 ; Maximum speeds (mm/min)
    M566 X1200 Y1200 Z1200 E1200 ; Maximum instant speed changes mm/minute
    ; Thermistors
    M305 P0 T100000 B3950 R4700 H30 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction
    M305 P1 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction
    M305 P2 T100000 B3974 R4700 H30 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
    M570 S180 ; Hot end may be a little slow to heat up so allow it 180 seconds
    M106 P2 T45 H1 ;thermostatic mode for fan 1 - Hotend fan
    ; Tool definitions
    M563 P0 D0 H1 ; Define tool 0
    G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures
    ;*** If you have a single-nozzle build, comment the next 2 lines
    M563 P1 D1 H2 ; Define tool 1
    G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
    M92 E476.5:476.5 ; Set extruder steps per mm
    ; Z probe and compensation definition
    ;*** If you have a switch instead of an IR probe, change P1 to P4 in the following M558 command
    M558 P5 R0.4 X0 Y0 Z0 H10 F1000 ; Z probe is an IR probe and is not used for homing any axes
    G31 X0 Y0 Z-0.1 P100 ; Set the zprobe height and threshold (put your own values here)
    ;*** If you are using axis compensation, put the figures in the following command
    M556 S78 X0 Y0 Z0 ; Axis compensation here
    M208 S1 Z-0.2 ; set minimum Z
    T0 ; select first hot end
    ; Auto calibration routine for delta printers
    ; Before running this, you should have set up your zprobe Z offset to suit your build, in the G31 command in config.g.
    M561 ; clear any bed transform, otherwise homing may be at the wrong height
    G31 X0 Y0 ; don't want any probe offset for this
    G28 ; home the printer
    ; Probe the bed and do 6- or 7-factor auto calibration
    G30 P0 X0.00 Y100.00 Z-99999 H0
    G30 P1 X50.00 Y86.60 Z-99999 H0
    G30 P2 X86.60 Y50.00 Z-99999 H0
    G30 P3 X100.00 Y0.00 Z-99999 H0
    G30 P4 X86.60 Y-50.00 Z-99999 H0
    G30 P5 X50.00 Y-86.60 Z-99999 H0
    G30 P6 X0.00 Y-100.00 Z-99999 H0
    G30 P7 X-50.00 Y-86.60 Z-99999 H0
    G30 P8 X-86.60 Y-50.00 Z-99999 H0
    G30 P9 X-100.00 Y-0.00 Z-99999 H0
    G30 P10 X-86.60 Y50.00 Z-99999 H0
    G30 P11 X-50.00 Y86.60 Z-99999 H0
    G30 P12 X0.00 Y50.00 Z-99999 H0
    G30 P13 X43.30 Y-25.00 Z-99999 H0
    G30 P14 X-43.30 Y-25.00 Z-99999 H0
    G30 P15 X0 Y0 Z-99999 S6
    G1 X0 Y0 Z150 F15000 ; get the head out of the way of the bed
  • Yes, you need to read the release notes - it's caught a lot of people out. To save you time, I've copied and pasted the relevant bit here…...........
    Important! If you use an IR Z probe or some other type that does not need to be deployed, delete the files sys/deployprobe and sys/retractprobe.g if they exist, because they are now called automatically. You can do this in the System Files Editor of the web interface.
  • Thank you.
