    eternal question about Z probing
    • Tinchusundefined
      Tinchus
      I have had this question on my mind for a long:
      my inductive Z probe has an offset of X-5 Y-30
      ON my home all and home Z routines, if I want to do the home Z on the center if my bed (220X220), should I send the coordinates X110 Y100 and then the G30 OR should I use the coodinates with the offset X115 Y130 so the probe is positioned in the middle of the print ed?
        Ideally position the probe at the center of the bed, and even better, position it exactly on one of the mesh points. Though in reality the amount of difference it would make is negligible if your mechanical setup is good.
