    Failed to enable endstops new build
    Using Duet Controllers
    853
    • chriswhitingundefined
      chriswhiting
      Hey finished mod an old Tronxy core XY with a new Z build plate mounted 3 t8 skews true bed level is working, and calibration seems ok?
      However every time I start a print I get the following error "Failed to enable endstops"
      I've been pulling my hair out now for a week"
      Config.g below
      ; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Oct 01 2022 13:40:55 GMT+1000 (Australian Eastern Standard Time)
      M550 P"Duet 3" ; set printer name
      M669 K1 ; select CoreXY mode
      M569 P0.1 S0 ; physical drive 0.1 goes forwards
      M569 P0.2 S0 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M569 P0.4 S1 ; physical drive 0.4 goes forwards
      M569 P0.5 S0 ; physical drive 0.4 goes forwards
      M569 P121.0 S1 ; physical drive 121.0 goes forwards
      M584 X0.1 Y0.2 Z0.3:0.4:0.5 E121.0 ; set drive mapping
      M92 X80.00 Y80.00 Z400.00 E400.00 ; set steps per mm
      M566 X1800.00 Y1800.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X12000.00 Y12000.00 Z320.00 E1200.00 ; set maximum speeds (mm/min)
      M906 X800 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M671 X120:0:320 Y0:320:320 S5
      M208 X330 Y330 Z350 S0 ; set axis maxima
      M574 X1 S1 P"121.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io1.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
      M558 P9 C"121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y0 Z1.05 ; set Z probe trigger value, offset and trigger height
      M557 X15:320 Y15:320 S24 ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out1" T0 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 R0.868 K0.492:0.000 D1.32 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
      M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency
      M106 P0 S1.0 H-1 ; set fan 0 value. Thermostatic control is turned off
      G10 P0 X0 Y0 Z1.945 ; set tool 0 axis offsets
        jay_s_uk @chriswhiting
        @chriswhiting post the contents of your homing files
        Actually, add a G4 S3 to your config just after the M669 to allow the CAN-FD connections to come online
        chriswhitingundefined 1 Reply Last reply Reply Quote 0
          chriswhiting @jay_s_uk
          @jay_s_uk [download (1).zip](Invalid file type. Allowed types are: .png, .jpg, .gif, .bmb, .pdf, .svg, .dxf, .cad, .txt, .doc, .xls, .docx, .xlsx, .stl, .csv, .g, .gcode, .stp, .step, .cps, .cbpp, .odt, .ods, .json, .scad, homex.g homeall.g homez.g homey.g .heic, .cpp, .c, .h, .py, .fcstd, .elf, .bin, .mp4, .jpeg, .hpp, .webp, .heic, .js, .qoi, .gc)
          chriswhitingundefined jay_s_ukundefined 3 Replies Last reply Reply Quote 0
            chriswhiting @chriswhiting
            @chriswhiting trying the G4 S3 now
              @chriswhiting
              homex.g
              ; homex.g
              ; called to home the X axis
              G91               ; relative positioning
              ;G1 H2 Z5 F6000    ; lift Z relative to current position
              G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass)
              G1 X5 F6000       ; go back a few mm
              G1 H1 X-335 F360  ; move slowly to X axis endstop once more (second pass)
              ;G1 H2 Z-5 F6000   ; lower Z again
              G90               ; absolute positioning
              homey
              ; homey.g
              ; called to home the Y axis
              G1 H1 Y-335 F1800 ; move quickly to Y axis endstop and stop there (first pass)
              G1 Y5 F6000       ; go back a few mm
              G1 H1 Y-335 F360  ; move slowly to Y axis endstop once more (second pass)
              homez
              ; homez.g
              ; called to home the Z axis
              ;G91               ; relative positioning
              ;G1 H1 Z-355 F1800 ; move Z down until the endstop is triggered
              ;G92 Z0            ; set Z position to axis minimum (you may want to adjust this)
              ;G1 Z5 F100       ; lift Z relative to current position
              ;G90              ; absolute positionin
              G91                ; relative mode
              ;G1 H2 Z2 F200      ; raise head 4mm to ensure it is above the Z probe trigger height
              G1 X0 Y0 F2000 ; put head over the centre of the bed, or wherever you want to probe
              G30                ; lower head, stop when probe triggered and set Z to trigger height
              G90  ; back to absolute mode
              homeall
              ; homeall.g
              ; called to home all axes
              ; generated by RepRapFirmware Configuration Tool v3.3.12 on Tue Sep 06 2022 18:33:17 GMT+1000 (Australian Eastern Standard Time)
              G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass)
              G1 H1 X-335             ; home X axis
              G1 H1 Y-335             ; home Y axis
              G1 X5 Y5 F6000          ; go back a few mm
              G1 H1 Y-335             ; then move slowly to Y axis endstop
              G1 H1 Z-355 F360        ; move Z down stopping at the endstop
                @chriswhiting the error is homeall tried to home with an endstop and homez homes with a probe
                  @chriswhiting Nup same outcome "Failed to enable endstops" just after extruder start heating
                    @chriswhiting ok that seemshomez.g homey.g homex.g homeall.g config.g bed.g to fix the error message, however now I'm getting " Attempting to extrude with no tool selected." <grrrrrr>
                      @chriswhiting add T0 to the end of your config
                        @jay_s_uk did you mean config.g ?
                          @chriswhiting yes
                            @jay_s_uk OK did that and print seems to run. I have a z height issue, but it may not be related.
                            One problem now is Z doesn't probe when I select home all and does when I select home z? homez.g homeall.g config.g
                              @chriswhiting I think I might have fixed the home all issue
                              homeall.g
                                @chriswhiting thats better.
                                It's also suggested to probe in the centre of the bed for homing.
                                  @jay_s_uk Understood that's me being inpatient 🙂
                                    @chriswhiting Grrr calibrated my Z probe offset height to 1.28 and it's printing the first layer about 4mm above the bed?
                                    bed.g homez.g homeall.g config.g
                                      @chriswhiting you have no X and Y offsets for your probe
                                      G31 P500 X0 Y0 Z1.2                         ; set Z probe trigger value, offset and trigger height
                                      what type of probe is it and how did you calibrate it?
                                        @jay_s_uk its a bltouch and I used this
                                        https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe#Section_Calibrate_the_Z_probe_trigger_height
                                          @chriswhiting Tried again and changed
                                          M558 P9 C"121.io0.in" H1.945 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
                                          Same problem?
                                          config.g
                                            @chriswhiting thats not where you set the probe offset. its set using G31, the next line down from M558
