    Failed to enable endstops new build
    Using Duet Controllers
    889
    • chriswhitingundefined
      chriswhiting @jay_s_uk
      @jay_s_uk Yes I just worked that out and corrected it however, it's still not working
        jay_s_uk @chriswhiting
        @chriswhiting can you post a photo of your setup?
        chriswhitingundefined 1 Reply Last reply Reply Quote 0
          @jay_s_uk It's not pretty 🙂
          IMG_0868.pdf
          IMG_0869.pdf IMG_0870.pdf
            chriswhiting @chriswhiting
            @chriswhiting OMG I think I have it working, had to add some g code to the slicer,
            ; XY-3 Start Code
            G21 ; Set units to millimeters
            G90 ; Set all axis to Absolute
            M82 ; Set extrusion to Absolute
            M107 ; Disable all fans
            M190 S{material_bed_temperature_layer_0} ; Set bed temperature and wait
            G28 ; Home all axis
            ; Uncomment the line below to enable ABL Mesh probing
            ;G29 ; Probe bed mesh for ABL
            ; For best results do not run nozzle heater while performing ABL
            G1 Z5.0 ; Raise nozzle to prevent scratching of heat bed
            G1 X0 Y0 ; Move nozzle to Home before heating
            M109 S{material_print_temperature_layer_0} T0 ; Set nozzle temp and wait
            G92 E0 ; Set Extruder position to zero
            ; Uncomment the following lines to enable nozzle purge line along left edge of bed
            ;G1 Z2.0 F3000 ; Raise Z axis
            ;G1 X1.1 Y20 Z0.2 F3600.0 ; Move to purge line start position
            ;G1 Y220 F1500.0 E10 ; Draw first purge line
            ;G1 X1.4 F3600.0 ; Move to side
            ;G1 Y20 F1500.0 E20 ; Draw second purge line
            ;G92 E0 ; Reset Extruder
            ;G1 Z2.0 F3000 ; Move Z Axis up little to prevent scratching of Heat Bed
            ;G1 X5 Y20 Z0.2 F3600.0 ; Move over to finish nozzle wipe
            ;G92 E0
            chriswhitingundefined 1 Reply Last reply Reply Quote 1
              @chriswhiting Thanks so much for responding so quickly and providing A grade assistance
