    Delete declared tools
    Using Duet Controllers
    • hauschkaundefined
      hauschka
      I'm looking for a way to delete declared tools (and fans, heaters, thermistors,...).
      Sceanrio: I have declared 2 tools, but want to replace them with new toolheads.
      Solution:
      • "Delete" existing tools
      • Declare new heads.
      Right now, i can only do this by resetting the machine. Is there a gcode that I'm missing to delete/undeclare tools, fans heaters, thermistors etc? or is a soft reset the only way to do so?
        jay_s_uk @hauschka
        @hauschka you can nil pin names etc, but editing the config and then restarting is the cleanest method. any issues with rebooting the machine?
          @hauschka you can delete a tool using M563 P# H-1 D-1 where # is the tool number.
          You can delete a heater or fan by sending a new M950 command for it with pin name "nil".
          • hauschkaundefined
            hauschka
            I see, thank you very much for the insights!
            • deckingmanundefined
              deckingman @hauschka
              @hauschka Alternatively, if you are likely to switch back and forth, you could create two (or more) configuration files and switch between them. Check out M505 https://docs.duet3d.com/User_manual/Reference/Gcodes#m505-set-configuration-file-folder
