    Best way to submit gcode from a program
    Duet Web Control
    • achrnundefined
      achrn
      If I want to submit gcode to a RRF printer from a program running on a PC elsewhere on the network, what is the best way to do that?
      That is, I'm generating gcode from a perl script and I want the script to immediately and automatically send the gcode to the printer and have the printer immediately run it. The printer is not running on a SBC (it is actually a sand table running on a fly e3 pro, but I think that's not terrifically relevant beyond that I can't run SBC mode, I think).
      I don't need to retain the generated gcode (on either the PC or the printer) though it's not a problem if it does remain and I clear out the gcodes directory manually periodically.
      Currently my perl generates the gcode into a file on disk (in this case called circles.g), then immediately e.g.:
      curl --data-binary @circles.g http://192.168.53.48/rr_upload?name=/gcodes/circles.g
      curl http://192.168.53.48/rr_gcode?gcode=M32/gcodes/circles.g
      curl http://192.168.53.48/rr_disconnect
      This works fine if I have recently connected a web browser to the DWC on the printer, but if I haven't, it doesn't work (for reasons I haven't worked out).
      1: Why does it not work if I haven't recently connected to the RRF printer?
      2: Is there a better way of doing this?
      chrishammundefined o_lampeundefined 2 Replies Last reply Reply Quote 0
      • chrishammundefined
        chrishamm administrators @achrn
        @achrn You may need to call rr_connect?password=XXX as well if you have a password set. If DWC is connected, your IP address is permitted to send upload/G-code requests already, so rr_connect is not needed then.
        Duet software engineer
        achrnundefined 1 Reply Last reply Reply Quote 0
        • o_lampeundefined
          o_lampe @achrn
          @achrn said in Best way to submit gcode from a program:
          Without DWC you can send gcode line_by_line, I guess.
          • achrnundefined
            achrn @chrishamm
            @chrishamm @o_lampe thanks both for the input, but it turns out it was actually user stupidity.
            I don't have a password and don't need a rr_connect but when I was connecting from a program and submitting the gcode file I was forgetting that axes aren't homed yet - so nothing (visibly) happens.
            When I connect a web browser I have been hitting the 'Home All' button immediately, and then (surprise!) uploaded gcode files run, but I have spent weeks not noticing that every time I connect with a web browser I immediately hit that button!
            The fix therefore was as simple as adding a G28:
            curl http://192.168.53.48/rr_gcode?gcode=G28
            Actually, I have now left in a http://192.168.53.48/rr_connect?password= (but with nothing specified as password) because it gives a potentially useful confirmation of the device - {"err":0,"sessionTimeout":8000,"boardType":"STM32F4","apiLevel":1}, but it isn't required.
            For posterity, I should note that without a password set on the printer a plain rr_connect without the password= appended doesn't work - it returns (in an html page) 'Your Duet rejected the HTTP request: Unknown request'.
