    M409 documentation possible error
    Documentation
    • achrnundefined
      achrn
      https://docs.duet3d.com/User_manual/Reference/Gcodes#m409-query-object-model lists as an example M409 K"move.axes.homed" ; for all axes, report whether it is homed
      That doesn't seem to work for me.
      M409 K"move.axes[0].homed" (or any specified axis) works fine, but the example given for all axes doesn't give a useful response.
      I get the same behaviour on fly_e3_pro running RepRapFirmware for STM32F4 based Boards 3.4.0_1 (2022-03-17) and on a Duet 3 MB6HC (MB6HC) running RepRapFirmware for Duet 3 MB6HC 3.4.2 (2022-09-13) .
        droftarts administrators @achrn
        @achrn thanks, I’ll fix it when I get a chance. I think that would have worked in earlier versions of RRF, but the object model has got more sophisticated over time.
          @achrn @droftarts to report all "homed" fields of the "axes" array, use M409 K"move.axes[].homed".
          achrnundefined 1 Reply Last reply Reply Quote 0
          • achrnundefined
            achrn @dc42
            @dc42 Thanks. That works, but using it leads me to notice that my object model has three axes even though I've only got two in the machine (with M584 X0 Y3 P2 in config.g). It's not a big deal, but is there a way to limit the object model to two axes?
              dc42 administrators @achrn
              @achrn I think M584 P2 may do that but I am not certain.
              • droftartsundefined droftarts marked this topic as a question
              • droftartsundefined droftarts has marked this topic as solved
