    Duet CNC Pendant
    Using Duet Controllers
    • Nightowlundefined
      Nightowl
      I'm using this pendant to jog my CNC, but the connection is somewhat intermittent, when first starting the CNC.
      I have noticed, however, that when the pendant connects to the controller (via an app on my Surface Pro) it reports a connection via Telnet port 23.
      Would it be appropriate to enable this port in the config.g file, e.g:
      ; Configuration file
      M453			; set machine to CNC mode
      G90                     ; send absolute coordinates...
      M83                     ; ...but relative extruder moves
      M550 P"Weeble"		; set printer name
      M552 P0.0.0.0 S1        ; enable network and acquire dynamic address via DHCP
      M586 P0 S1              ; enable HTTP
      M586 P1 S0              ; disable FTP
      M586 P2 S1              ; enable Telnet
      ...but I'm not sure how to specify the port number, or if I even need to.
      I'm using a Duet3 MB6HC controller, with 3.4.3 firmware installed.
      Thank you
      Few things are more dangerous than taking the advice of someone who thinks he knows what he's doing.
      I'm still on my learning curve, so take everything I say with caution!
      RatRig 1075, Duet3 MB6HC, Sorotec SFM 1000 PV-ER milling motor, Hobbyist
        dc42 administrators @Nightowl
        @Nightowl see https://docs.duet3d.com/User_manual/Reference/Gcodes#m586-configure-network-protocols for how to configure the port number, in particular the R parameter.
        Nightowlundefined 1 Reply Last reply Reply Quote 0
        • Nightowlundefined
          Nightowl @dc42
          Thank you, @dc42
          I only remember TCP as being an antiseptic used for gargling, if you had a sore throat, or for small cuts!
          Whoops 😊 😊
            @Nightowl the default port number for Telnet is 23 anyway.
            • Nightowlundefined
              Nightowl @dc42
              Thank you @dc42
