PT100 weirdness
Just to be sure what to do now, I ordered from you/Tony so I write to info@duet3d.com or what?
Yes.
Ok got the new daughter board today. At first thanks to Tony/David for the quick replacement!
Tested with two resistors on the DWF first and the readings have been reasonable.
I monitored the PT100 connections for any leak voltage when moving carriages, switching on heaters and fans to be sure there is not voltage on the heater channel by accident. No voltage could be monitored so.
Then connected both PT100 and looks good for now:
