5v to power my Neopixel from Duet 2 wifi
@cosmowave Look at this photo .
@Karim If your LED's don't need to much current it is ok to wire them directly on the CONN_LCD.
Else you should use your external power supply. -
@cosmowave it's just 3 neopixel for my tool head light.
@Karim said in 5v to power my led from Duet.:
Should be no problem...
Don't forget the level shifter! -
@cosmowave this is where I am confuse, do I still need the level shifter. I am getting 5v +- and signal from the duet 2 Wi-Fi.
@Karim The signal port has only 3.3V!
@cosmowave Thank you . I am waiting for the part.
Minimum signal level for a Neopixel is 0.7xVdd, so while you might be getting lucky that it works (in this moment, at least), saying a level shifter is not needed is incorrect.
@Karim see https://learn.adafruit.com/neopixel-levelshifter for information on Neopixels and 3.3V logic levels.
There is a newer type of Neopixel LED called the WS2812B-V5 which is specified to accept 3.3V signal levels when using a 5V supply, but they are not easy to find yet.
@dc42 Thank You
