BlTouch… Quasi works
  • Hi…
    I am triying to do work BlTouch.... and afted hundred of test, i have discovery somethigs:
    First, what the diference beteewn
    Deploy BlTouch: M280 P0 S10 (This is the gcode, in Antlabs web) and M280 P3 S10 I1 (This is the gcode in this forum)
    Retract BLTouch: M280 P0 S90 (This is the gcode, in Antlabs web) and M280 P3 S90 I1 (This is the gcode in this forum)
    M280 - This send the gcode to servo.
    P0 - The number of the servo... When is P0 and when is P3???
    S0/S90 - Angle/Microsegonds, suppose, the duration of the pulse in the order to deploy o retract...
    I1 - I dont know....i haven't see this flag in wiki...
    I think i am in the way, now i dont have, but near miss... one word SOLENOID.
    BlTouch have in upper and screew to adjust the "force" of solenoid....
    Well after test i have discover:
    • When, in start screen, Sensors/Z Probe is Greyed, BlTouch is in error mode, and no signal sends.
    • The BlTouch, respond at the commands of Deploy, Retract and Test.
    • When BlTouch was working in Smoothieware Board... Works correct. The issues has come when i have changed Smoothieware to DUET3D WIFI board.
    • The blue led is on, depend the position of top screw, i have read that is the force of solenoid activates. In this moment i am doing test with this, tightening and loosening the screw, i am following this metod (please check)
      A- Turn off printer
      B- I loosen the screw until exit above the Bltouch about 1 mm
      C- Turn on printer
      D- See if blue led is on, if this is the case E, and is of I
      E- Power off the printer
      F- I tighten the screw 1/4 turn
      G- POwer on the printer
      H- Go to D
      I- Send by console, this commands M280 P3 S10 I1 (deploy) M280 P3 S90 I1 (retract)
      J- In this moment i am here... the problem in this moment, when i send the command to retract, BlTouch enter in error mode (Start to blink) and i have to send a reset
      gcode... and when i do this, BlTouch, belive, dont send to duet his actual position...
    I have measure tension, when is retracted or deployed (i dont remember) and can read with multimeter 3,1.... a little low? No. Or is suficient for Duet understand that it is activated?
    There is some sytem for this tension will be more near 3,3V?
    @peirof:
    Hi…
    P3 says which output pin you are using (heater 3 on the expansion connector). I1 means invert the signal, because the heater signals on the expansion connector are inverted.
  • P3 correspond to Heater 3 (pin 8).? Orange wire?
