    Display toolboard temperature on dashboard
    Duet Web Control
    • kuonundefined
      kuon
      Is it possible to display the toolboard temperature (reported by M122 Bxx) on the dashboard?
      • T3P3Tonyundefined
        T3P3Tony administrators @kuon
        @kuon
        See :https://docs.duet3d.com/User_manual/Reference/Gcodes#m308-set-or-report-sensor-parameters
        To read mcu and driver temperatures on an expansion board connected to a Duet 3 mainboard, set the CAN address in the P parameter. For example, a board at CAN address 1 would use:
        M308 S12 Y"mcu-temp" P"1.dummy" A"3HC MCU"
        M307 S13 Y"drivertemp" P"1.dummy" A"3HC Steppers"
        Note that from RRF 3.4.0 beta 8, "drivertemp" will be changed to "drivers" to match the main board.
        so for example a toolboard on CAN address 20, setup to use sensor number 12
        M308 S12 A"Toolboard MCU" Y"mcu-temp" P"20.dummy"
        gives
        www.duet3d.com
        kuonundefined 1 Reply Last reply Reply Quote 1
        • kuonundefined
          kuon @T3P3Tony
          @T3P3Tony Thanks. I totally missed that in the doc.
