    Trouble getting Duet3 running, new board
    Firmware installation
    • NOVAprintundefined
      NOVAprint
      It is strange that I have had these difficulties with the firmware. I hope to someday install firmware without any snags. Not today.
      I have a duet 3 mini 5+.
      I used the configuration tool to get the right firmware and commands under duet 3. Here is a copy of my m115
      m115
      FIRMWARE_NAME: RepRapFirmware for Duet 3 Mini 5+ FIRMWARE_VERSION: 3.3RC2 ELECTRONICS: Duet 3 Mini5plus WiFi FIRMWARE_DATE: 2021-05-11 14:55:40
      ok
      My config G
      ; Configuration file for Duet 3 Mini 5+ (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sun Oct 23 2022 21:15:12 GMT-0400 (Eastern Daylight Time)
      M550 P"LRNSenior" ; set printer name
      M665 R105.6 L215 B85 H175 ; Set delta radius, diagonal rod length, printable radius and homed height
      M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
      M918 P1 E4 F2000000 ; configure direct-connect display
      M551 P"elbow7986diesel" ; set password
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M587 S"SETUP-AF8D" P"elbow7986diesel" : added to attempt connect 10/23/2022
      M569 P0.1 S1 ; physical drive 0.1 goes forwards
      M569 P0.2 S1 ; physical drive 0.2 goes forwards
      M569 P0.3 S1 ; physical drive 0.3 goes forwards
      M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
      M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
      M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 Z0 S1 ; set minimum Z
      M574 X1 S1 P"io0.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin io0.in
      M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in
      M574 Z1 S1 P"io2.in" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin io2.in
      M558 P5 R0.4 C"io3.in+io3.out" H5 F1200 T6000 ; set Z probe type to effector and the dive height + speeds
      M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
      G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
      M557 R85 S20 ; define mesh grid
      M308 S0 P"temp0" Y"pt1000" ; configure sensor 0 as PT1000 on pin temp0
      M308 S1 P"temp1" Y"pt1000" ; configure sensor 1 as PT1000 on pin temp1
      M950 H1 C"out1" T1 ; create nozzle heater output on out1 and map it to sensor 1
      M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
      M950 F1 C"out6" Q500 ; create fan 1 on pin out6 and set its frequency
      M563 P0 S"se heater" D0 H1 F0 ; define tool 0
      T0 ; select first tool
      When I run m997 this is what I get
      m997
      Error: M997: In-application programming binary “0:/firmware/Duet3_SDiap32_Mini5plus.bin” not found
      ok
      My sd card structure
      bcm2708-rpi-b-plus.dtb
      bcm2708-rpi-b-rev1.dtb
      bcm2708-rpi-b.dtb
      bcm2708-rpi-cm.dtb
      bcm2708-rpi-zero-w.dtb
      bcm2708-rpi-zero.dtb
      bcm2709-rpi-2-b.dtb
      bcm2710-rpi-2-b.dtb
      bcm2710-rpi-3-b-plus.dtb
      bcm2710-rpi-3-b.dtb
      bcm2710-rpi-cm3.dtb
      bcm2711-rpi-4-b.dtb
      bcm2711-rpi-400.dtb
      bcm2711-rpi-cm4.dtb
      bootcode.bin
      cmdline.txt
      config.txt
      COPYING.linux
      filaments
      firmware
      fixup_cd.dat
      fixup_db.dat
      fixup_x.dat
      fixup.dat
      fixup4.dat
      fixup4cd.dat
      fixup4db.dat
      fixup4x.dat
      gcodes
      issue.txt
      kernel.img
      kernel7.img
      kernel7l.img
      kernel8.img
      LICENCE.broadcom
      macros
      menu
      overlays
      start_cd.elf
      start_db.elf
      start_x.elf
      start.elf
      start4.elf
      start4cd.elf
      start4db.elf
      start4x.elf
      sys
      www
      • T3P3Tonyundefined
        T3P3Tony administrators @NOVAprint
        @NOVAprint please follow the directions here to install 3.4.4 and as part of that the IAP file will be installed:
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Updating_firmware#usual-procedure
        Usual procedure
        1. Download firmware zip bundle (named Duet2and3Firmware-3.xxx.zip) , or individual binary files, from https://github.com/Duet3D/RepRapFirmware/releases
        2. Connect to DuetWebControl.
        3. In DWC, go to the System page and click the "Upload System Files" button.
        4. Browse to the new firmware zip file or individual firmware binary file you have downloaded.
        5. After uploading, Duet Web Control will ask you whether you want to install the new firmware. If you are updating using the firmware zip bundle, this will update firmware, IAP, WiFi firmware and DWC all at once, so click Yes.
          etc
        www.duet3d.com
