Choosing a wire size for extending stepper motor cables.
According to this site: http://www.solar-wind.co.uk/cable-sizing-DC-cables.html
At 24 V, 2.4 A steppers driven at 2 A, and 1 m long cable, I can get away with 26 AWG wiring (the same size typically found as the leads on NEMA 17) if 3% power loss is acceptable.
For 0.9 degree steppers, is 3% power loss acceptable? Thanks!
The 3% power loss is I presume 3% of 24V, so an extra 0.72V drop in the motor cables, if we assume that the calculator allows for the resistance of both conductors. That doesn't sound too bad.
By both conductors, do you mean the two wires to each pole? Do I need to calculate a "return-trip" voltage drop? I believe the calculator I used is not intended for stepper motors specifically, so I'm not sure if it considers any special circumstances present in the use of stepper motors (which, clearly, I'm unaware of).
