Problems with macros
Hello. I would like to write a macro that pauses my printer, homes the x and y axes, and then resumes.
I have tried creating a macro that calls pause.g, homex.g and homey.g, and then resume.g, but I just got some really bizarre shaking behavior, not at all like running those files from the dashboard. I also just copied and pasted the gcode from those files into one macro and the behavior was just as strange. What am I doing wrong here?
How were you calling those macros?
What exactly are you trying to do?
Do you really need to pause?
Is this intended to be doing during a print?To call a pause you'd probably want to call M25, then G28 X, then G28 Y, then M24 to resume.
https://docs.duet3d.com/User_manual/Reference/Gcodes#m25-pause-sd-print
@Phaedrux Thank you for your reply! Sometimes my nozzle will rake across a particularly rough patch, and cause a layer skip. I can hear it when this happens, so I press pause, then I re-calibrate the x and y axes, then I resume, and no problem. I was trying to make a macro that can do all 3. I will try doing what you said, M25 then G28 X and Y, then M24.
@tylersuard said in Problems with macros:
THAT would be the thing to spend time on. You should not be getting rough patches like that often enough to want to write a macro to work around it.
An occasional ooze or blob is one thing, but as I read your post, if this happens often, let figure what is causing the condition and fix it.
Yes solving the rough spots would be the best way to go.
If all you want to do is home the X and Y during a pause, simply add G28 XY to your pause.g macro.
