    CNC machin update 2.02 -> 3.x
    Firmware installation
    • jjudeundefined
      jjude
      Is it generally safe to update a CNC machine?
      What should be taken into account in the settings of the config file?
      Is there a fear that the same VCarve gcode will not work in the 3.x version?
      Or if i update 2.02->2.05.1 - HOW?
        I don't think there is any inherent problem with updating for a CNC. There's a few improvements actually.
        If you still have access to DWC. Upload these zip files, one at a time in the system tab. Don't extract them first. Reboot after each. Use M115 in the gcode console to verify the firmware has been applied.
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2and3Firmware-3.0.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.3/Duet2and3Firmware-3.4.3.zip
        https://github.com/Duet3D/RepRapFirmware/releases/download/3.4.4/Duet2and3Firmware-3.4.4.zip
        That will get your firmware and DWC up to date.
        You can see the change logs here:
        https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x
        For your config, might be a good idea to run through the configurator tool and generate a fresh set for RRF3.
        https://configtool.reprapfirmware.org/Start
        Backup your existing config files in the sys folder in case you want to switch back to RRF2. It’s easy to switch back and forth, just upload the zip file for the version you want and then upload your config files.
        These documents will come in handy during the conversion.
        https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview
        https://docs.duet3d.com/en/User_manual/RepRapFirmware/Migration_RRF2_to_RRF3
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes
