    About "status" in Gcode
    Gcode meta commands
    • Distance98undefined
      Distance98
      Recently I've been trying the ERCFonRRF project and and had some problems with it.
      In the load.g file,I see this command of command
      if state.status == "processing”
      but I don't know what this mean, I searched the meta command ,but didn't found it. So I come here ask for help
      where can I get the information about "state.status" and "processing"
      The complete code is as follow:
        Distance98
        load.g
        Here is the file
        cosmowaveundefined 1 Reply Last reply Reply Quote 0
        • cosmowaveundefined
          cosmowave @Distance98
          @Distance98 "processing" means that the controller is doing something and is NOT "idle"
          Mankati FSXT+, DeltaTowerV2, E3D MS/TC
            Distance98
            or just the printer is working?such as it is printing a model?
              @Distance98 Yes, of course.
                cosmowave @cosmowave
                @cosmowave
                here is a list of the possible current state of the machine
                • disconnected: Not connected to the Duet
                • starting: Processing config.g
                • updating: The firmware is being updated
                • off: The machine is turned off (i.e. the input voltage is too low for operation)
                • halted: The machine has encountered an emergency stop and is ready to reset
                • pausing: The machine is about to pause a file job
                • paused: The machine has paused a file job
                • resuming: The machine is about to resume a paused file job
                • cancelling: Job file is being cancelled
                • processing: The machine is processing a file job
                • simulating: The machine is simulating a file job to determine its processing time
                • busy: The machine is busy doing something (e.g. moving)
                • changingTool: The machine is changing the current tool
                • idle: The machine is on but has nothing to do
                Distance98undefined 1 Reply Last reply Reply Quote 1
                  Distance98 @cosmowave
                  @cosmowave OK,now I get it. Thank you!
