    High hotend position just on the first print
    • joaomedinaundefined
      joaomedina
      Very wired issue, yes i know.
      On the first print of the day, my print home all axis and begin to print really high above the bed, offset with Z Babystepping makes no changes at all. Do not use auto bed level.
      After stop this first one and send the same file again everything goes normal.
      Any tips on how to solve this wired one?
      I will post below the details that i think can be helpful:
      Ender 3 pro
      Electronics
      Board: biquskr_rrf_e3_1.1 (STMWiFi)
      Firmware: RepRapFirmware for STM32F4 based Boards 3.4.0_1 (2022-03-17)
      Duet WiFi Server Version: 1.26-05S-D
      config.g
      ; Configuration file for SKR-RFF-E3-v1.1 (firmware version 3)
      ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+7 on Sun May 08 2022 13:24:01 GMT-0300 (Horário Padrão de Brasília)
      M550 P"Ender3" ; set printer name
      M552 S1 ; enable network
      M586 P0 S1 ; enable HTTP
      M586 P1 S0 ; disable FTP
      M586 P2 S0 ; disable Telnet
      M569 P0 S0 ; physical drive 0 goes backwards using TMC2209 driver timings
      M569 P1 S0 ; physical drive 1 goes backwards using TMC2209 driver timings
      M569 P2 S1 ; physical drive 2 goes forwards using TMC2209 driver timings
      M569 P3 S0 ; physical drive 3 goes forwards using TMC2209 driver timings
      M92 X80.00 Y80.00 Z400.00 E96.00 ; set steps per mm
      M566 X1200.00 Y1200.00 Z60.00 E360.00 ; set maximum instantaneous speed changes (mm/min)
      M203 X9000.00 Y9000.00 Z1800.00 E6000.00 ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
      M84 S30 ; Set idle timeout
      M208 X225 Y225 Z250 S0 ; set axis maxima
      M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
      M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
      M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop
      ; M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
      ; M557 X15:215 Y15:195 S20 ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
      M307 H0 R0.309 K0.367:0.000 D0.86 E1.35 S1.00 B0
      ; M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
      M308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
      M307 H1 R2.641 K0.594:0.000 D6.20 E1.35 S1.00 B0 V24.0 ; PID Tune
      ; M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
      M143 H1 S260 ; set temperature limit for heater 1 to 260C
      M106 P0 C"Part Cooling Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
      M106 P1 C"Hotend Fan" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off
      G31 Z-0.5
      ;Ender Original LCD
      M918 P1 E4 F1000000
      homeall.g
      ; called to home all axes
      G91 ; relative positioning
      G1 H1 X-230 Y-230 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
      G1 H2 X5 Y5 F6000 ; go back a few mm
      G1 H1 X-230 Y-230 F360 ; move slowly to X and Y axis endstops once more (second pass)
      G1 H1 Z-255 F800 ; move Z down until the endstop is triggered
      G1 H2 Z5 F600 ; go back a few mm
      G1 H2 Z-10 F200 ; lower Z again
      G90 ; absolute positioning
      ;G91 ; relative positioning
      ;G1 Z5 F100 ; lift Z relative to current position
      ;G90 ; absolute positioning
      homez.g
      ; called to home the Z axis
      ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+7 on Sun May 08 2022 13:24:02 GMT-0300 (Horário Padrão de Brasília)
      • A Former User?
        A Former User @joaomedina
        @joaomedina In your homeall.g and homez.g
        I believe should be H1 not H2... H1 is for homing H2 is individual motor move
        I don't know if that will fix your issue, if not, maybe try adding a start.g file (it will automatically runs at the start of your print) and have it home Z again.
        joaomedinaundefined 1 Reply Last reply Reply Quote 1
          joaomedina @A Former User
          @wwak84 Thanks for your reply!
          Just had a small problem with my micro SD and build the RRF from scratch again. The issue is solved, sadly we will never know what cause it.
          • A Former User?
            @joaomedina Small problem with the micro sd indeed! Glad its working.
