    Help on Conditional for network
    Gcode meta commands
    583
    • mikeabuilderundefined
      mikeabuilder
      I'm looking for some advice on making the wifi connection conditional on my Duet2 wifi. My situation is that I have the board set up with a PanelDu and use the wifi connection and DWC for debugging, but I want "normal operation" to be without the wifi. I set up a wifi router for debug, and when this router is not running (normal operation), I get continual messages on the PanelDu that the network is not connected.
      My simple idea is that in my config.g, after turning on the network, I check if the network interface state is active. If not, I use a G4 to wait a bit for the connection to be made, then look at the object model again . If the network is still not active, I send an M552 S0 to turn off the network.
      When I implemented this, I can't get the network to stay connected, even when the delay is up to 30 seconds. It seems like
      So, is my reasoning sound? And to the obvious question - can I post my code? I foolishly left it on the printer in my makerspace and wo'n't get to it until next Tuesday, but I believe it looked like this:
      ;START OF NETWORKING SETUP
      		;!## Networking
      		;! Set up networking parameters.
      M552 S1        ;! Enable Network
      M586 P0 S1     ;! Enable HTTP
      M586 P1 S0	   ;! Netmask
      M586 P2 S0     ;! Disable Telnet
      if network.interfaces[0].state != "active"   ;If the netwokr is not yet active
        G4 S30                                     ; wait 30 seconds for it to become active
          M552 S0
      ;END OF NETWORKING SETUP
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @mikeabuilder
        @mikeabuilder
        The list of possible states is
        network.interfaces[].state
        Network state
        This property may be one of the following:
        disabled: Network disabled
        enabled: Network enabled but not started yet
        starting1: Starting up (used by WiFi networking in standalone mode)
        starting2: Starting up (used by WiFi networking in standalone mode)
        changingMode: Running and in the process of switching between modes (used by WiFi networking in standalone mode)
        establishingLink: Starting up, waiting for link
        obtainingIP: Link established, waiting for DHCP
        connected: Just established a connection
        active: Network running
        Have you checked the the state is actually "active" when the board is connected to your wifi?
          mikeabuilder
          @OwenD Yes I have. If I comment out lines 10-13 in the code above and, power cycle the board and let it connect, then I can echo network.interfaces[0].state and "active" is returned.
          • OwenDundefined
            OwenD @mikeabuilder
            @mikeabuilder
            I did some testing.
            It seems that the network connection isn't done until after config.g is finished processing.
            I used the following code to check.
            echo >"myLog.txt" state.upTime, "secs. state:", network.interfaces[0].state, "IP:", network.interfaces[0].actualIP
            while (network.interfaces[0].state != "active") && (state.upTime < 90)
            	echo >>"myLog.txt" state.upTime, "secs. state:", network.interfaces[0].state, "IP:", network.interfaces[0].actualIP
            If the code was anywhere in config.g, then the state remained "disabled" and it would time out, simply filling the file with the same line of text.
            After that, the network would connect normally.
            If I put the code in daemon.g, I got this.
            18 secs. state: changingMode IP: 0.0.0.0
            19 secs. state: changingMode IP: 0.0.0.0
            19 secs. state: active IP: 192.168.1.163
            So if you modify my code and put it in daemon.g you should achieve what you want.
            OwenDundefined dc42undefined 2 Replies Last reply Reply Quote 0
            • OwenDundefined
              OwenD @OwenD
              @mikeabuilder
              In thinking about this I thought you might be able to use whether or not you have a wifi signal and/or whether or not the network was enabled to avoid running the code every time daemon.g is invoked, but in my case the object model does not show a signal value even though it is reported in M122
              My idea was to use
              if (network.interfaces[0].state != "active") && (state.upTime > 90) && (network.interfaces[0].signal < -50) ; or whatever value
                 M552 S0
              However the object model doesn't expose whether networking is active (unless the interface becomes null when it's not?)
              And I don't get a signal in the object model.
              Perhaps @dc42 can comment
              M122
              = WiFi =
              Network state is active
              WiFi firmware version 1.27
              WiFi MAC address bc:dd:c2:89:a0:bb
              WiFi Vcc 3.38, reset reason Power up
              WiFi flash size 4194304, free heap 24352
              WiFi IP address 192.168.1.163
              WiFi signal strength -52dBm, mode 802.11n, reconnections 0, sleep mode modem
              Clock register 00002002
                mikeabuilder
                @OwenD - that's for your further thoughts on this. I'll, pursue the daemon method. I'll set a global variable in config.g (last line) and use this in an if statement in daemon for enable running the code to look for an active network connection.
                global daemon_network_check = 1
                Then in daemon.g:
                if exists global.daemon_network_check  ; needed in case the daemon runs before config.g finishes.
                  if global.daemon_network_check <=3  ;three tries will give the network 30 seconds to connect. I might reduce this after testing.
                    if network.interfaces[0].state = "active"
                      global.daemon_network_check = 99
                    else
                      if global.daemon_network_check = 3 ;  no network after three tries
                        M552 S0           ; disable networking
                      global.daemon_network_check = global.daemon_network_check+1
                Maybe I can streamline this some, but that's the general idea.
                  dc42 administrators @OwenD
                  @OwenD said in Help on Conditional for network:
                  That's correct, RRF waits until the end of config.g before enabling the network, in case there are commands in config.g that change the network parameters.
                  • OwenDundefined
                    OwenD @mikeabuilder
                    @mikeabuilder
                    I thought of a hack that would avoid using daemon.g and global variables.
                    If you're not using daemon.g in a loop, it's doing a disk read every 10 seconds.
                    Seems pointless for a task that's only ever going to be required at startup and would avoid having network disabled if you lost wifi signal temporarily.
                    At the start of your config.g call this macro to create a runonce.g
                    M98 P"create_runonce.g"
                    ; create_runonce.g - creates a file that is run after config.g is run and network is enabled
                    echo >"0:/sys/runonce.g" "G4 S20 ; give the network time to establish connection"
                    echo >>"0:/sys/runonce.g" "if network.interfaces[0].state != ""active"""
                    echo >>"0:/sys/runonce.g" "  M552 S0           ; disable networking"
                    echo >>"0:/sys/runonce.g" "  M291 R""Network check""  P""Disable networking"" S0 T3"
                    echo >>"0:/sys/runonce.g" "else"
                    echo >>"0:/sys/runonce.g" "  M291 R""Network check""  P""Network active"" S0 T3"
                    From the documents
                    runonce.g
                    File runonce.g is supported from RRF3.1.0 and later. If this file is present at startup, it is run after running config.g and activating the network, and then deleted.
                    dc42undefined 1 Reply Last reply Reply Quote 2
                      Once you have determined whether the network us running or not and taken any appropriate action, you can execute e.g. G1 G4 S9999 in a loop in daemon.g to avoid looking at the SD card every 10 seconds.
                        mikeabuilder
                        Thanks for the comments. I may be asking for more detail than I can fully understand, but I have two questions/comments.
                        In my proposed code above, the first and second nested if's query the state of a global variable, and the of those will stop execution whether the network is running or not. It either counts counts to the limit and gives up on the network (and the value is set to 4), or the network is alive and the value set to 99. In either case, every time the daemon runs after that, the object model will not be queried. So my question is - does RRF store the value of global variables on the SD card? Also, are the object model variables stored on the SD card? I would have guessed both the object model and global variables are stored in memory.
                        Second question - @dc42 you offer using G1 S9999 in a loop. I looked at G1 in the gcode dictionary page and don't see a definition that helps me understand this path. It references the S parameter on G1 as pertaining to laser. If tehre is no laser, does this make a G1S9999 a no-op?
                        • OwenDundefined
                          OwenD @mikeabuilder
                          @mikeabuilder
                          You are correct in assuming that the OM and globals are stored in memory.
                          daemon.g normally gets run once every 10 seconds.
                          Each time it runs, it reads the contents of the macro from the SD card, performs whatever you coded, then exits.
                          To avoid that card read, you can put a while loop in daemon.g so that it never exits.
                          However you must put a G4 dwell in to hand control back to the main process ( @DC42 made a typo with G1)
                          The very long dwell fsuggested by DC42 would avoid the constant checking of the if conditions.
                          while true
                            ;do your stuff
                            G4 S9999999 ; not sure the maximum
                            @OwenD thanks for pointing out my typo.
                            The maximum G4 parameter supported is 2^31 milliseconds (P parameter) so (2^31)/1000 seconds (S parameter).
                              mikeabuilder
                              Thanks @OwenD and @dc42, I'll put my new knowledge to the test later today.
                              It's good to understand that daemon.g always reads the current daemon.g file before running, but this read overhead seems very tiny and will occur in any event - even for my current daemon.g file that only has a comment in it to remind me what the daemon.g file is for.
                              As the read time is the only downside to the code I put in this thread above, I'm going to implement it and assess the results.
                                mikeabuilder
                                Just tested my code and it works very well - after I fixed my typos and syntax errors.
