Control server needs to be restarted on emergency shut down
@chrishamm The hostname is local LAN address. If I try with the IP directly I get the same result.
I noticed something, when the error is present, I get the following logs:
Nov 22 01:17:03 lili systemd[1]: Starting Duet Control Server... Nov 22 01:17:06 lili DuetControlServer[301]: Duet Control Server v3.4.4 Nov 22 01:17:06 lili DuetControlServer[301]: Written by Christian Hammacher for Duet3D Nov 22 01:17:06 lili DuetControlServer[301]: Licensed under the terms of the GNU Public License Version 3 Nov 22 01:17:07 lili DuetControlServer[301]: [info] Settings loaded Nov 22 01:17:07 lili DuetControlServer[301]: [info] Environment initialized Nov 22 01:17:07 lili DuetControlServer[301]: [info] Connection to Duet established Nov 22 01:17:08 lili DuetControlServer[301]: [info] IPC socket created at /run/dsf/dcs.sock Nov 22 01:17:08 lili systemd[1]: Started Duet Control Server. Nov 22 01:17:08 lili DuetControlServer[301]: [info] Starting macro file config.g on channel Trigger Nov 22 01:17:11 lili DuetControlServer[301]: [info] Finished macro file config.g When I restart the server manually, I get this output:
Nov 22 14:32:00 lili systemd[1]: Starting Duet Control Server... Nov 22 14:32:00 lili DuetControlServer[905]: Duet Control Server v3.4.4 Nov 22 14:32:00 lili DuetControlServer[905]: Written by Christian Hammacher for Duet3D Nov 22 14:32:00 lili DuetControlServer[905]: Licensed under the terms of the GNU Public License Version 3 Nov 22 14:32:01 lili DuetControlServer[905]: [info] Settings loaded Nov 22 14:32:01 lili DuetControlServer[905]: [info] Environment initialized Nov 22 14:32:01 lili DuetControlServer[905]: [info] Connection to Duet established Nov 22 14:32:01 lili DuetControlServer[905]: [info] IPC socket created at /run/dsf/dcs.sock Nov 22 14:32:01 lili systemd[1]: Started Duet Control Server. The two lines about
config.g
are missing, but in this case, it works and I can access the web UI.If I empty my config.g and only leave the password and hostname the issue persists.
@kuon Right,
config.g
is not executed when you restart the DSF service and DSF will keep using the default (unset) password, so actually you should put yourM551
intodsf-config.g
which is always executed when you restart the Pi or the DCS service in general.Please share your current
config.g
file, the only reason I can think of why it isn't working is an error somehwere in your configuration file.M551
works properly on my SBC setup no matter what I do. Note thatM551
and HTTP password protection wasn't supported in earlier DSF versions, so that might have just concealed the problem. -
@chrishamm As I said, I tried with a
config.g
containing only those two lines:M551 P"xxxx" ; printer password M550 P"lili" ; printer name -
@kuon That works for me, I can repeatedly connect with "xxxx" as the password upon E-STOP using Firefox and MS Edge.
I realized something, if I restart the server with
sudo systemctl restart duetcontrolserver.service
then load the web UI (not prompted for password, so so far, so good), then I issue theM551
gcode using the UI, and after that hit F5 to reload the page, I am prompted for password, and if I enter the password it works, but if Ireload the page again, I still get prompted. It seems the session is not sticking.Is that intended behavior? Because maybe my
M551
was not being set and I was actually using the machine without a password. And also that prusa slicer is not supporting the proper way to use Duet API with a password. -
@kuon Yes, it is, see my previous comment.
config.g
is only executed when RRF starts but not when DCS is restarted, so you should put M550/M551 indsf-config.g
instead. The machine password is stored by DCS and not RRF, so it is cleared upon restart if it is only in config.g -
@chrishamm said in Control server needs to be restarted on emergency shut down:
config.g
instead. The machine password is stored by DCS and not RRF, so it is cleared upon restart if it is only in config.gdsf-config.g
must be activated in some way? Because I just tried and it has no effect. I added theM551
andM550
in it. (which I removed fromconfig.g
) The name in the UI defaults to the hostname of the PI instead of theM550
value I set.Also, is it normal that the UI prompt for password on each reload and that it does not set a persistent session?
@kuon is this a fresh install or have you been upgrading the SBC side for a while?
@jay_s_uk I have been upgrading for a long time, maybe that's what is causing the issue. I can try a fresh install.
@kuon i would try a fresh install because the duetpimanagement plugin wasn't around until RRF3.3
@kuon no, dsf-config.g is automatically called by DCS and does not require the management plugin. Neither do M550 or M551. In order to apply it, ESTOP or a service restart is needed.
@chrishamm I did restart the service with
systemctl
and it does not applydsf-config.g
. To test it, I have noM550
inconfig.g
andM550 P"Hello"
indsf-config.g
. If I restart the service or emergency stop and then reload the page, the hostname is still used on the top left, and runningM550
returns the hostname as well. (instead ofHello
@kuon I have no good explanation why
dsf-config.g
isn't executed on your system, perhaps a permission thing? Make sure it is present in yoursys
directory (also available as/opt/dsf/sd/sys
on Linux) and that it is readable by thedsf
user/group.When I restart DCS, I can see
Nov 22 18:41:55 Ender3Pro systemd[1]: Stopped Duet Control Server. Nov 22 18:41:55 Ender3Pro systemd[1]: duetcontrolserver.service: Consumed 6.445s CPU time. Nov 22 18:41:55 Ender3Pro systemd[1]: Starting Duet Control Server... Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: Duet Control Server v3.4.4 Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: Written by Christian Hammacher for Duet3D Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: Licensed under the terms of the GNU Public License Version 3 Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: [info] Settings loaded Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: [warn] Support for third-party root plugins is enabled Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: [info] Environment initialized Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: [info] Connection to Duet established Nov 22 18:41:56 Ender3Pro DuetControlServer[1360]: [info] IPC socket created at /run/dsf/dcs.sock Nov 22 18:41:56 Ender3Pro systemd[1]: Started Duet Control Server. Nov 22 18:41:59 Ender3Pro DuetControlServer[1360]: [info] Starting macro file dsf-config.g on channel SBC Nov 22 18:42:00 Ender3Pro DuetControlServer[1360]: [info] Finished macro file dsf-config.g which proves it is executed correctly.
Also note that in SBC mode
M550
may be used without the DuetPiManagementPlugin only to decorate the hostname, e.g. to change the caption from "ender3pro" to "Ender 3 Pro" (i.e. to change casing and to add spaces). For system-related changes on Linux, the DuetPiManagementPlugin is mandatory.Since I cannot reproduce any of your problems here, it may actually be a good idea to backup your config, obtain our latest DuetPi or DuetPi Lite image again, and then see if the problems persist once your SBC is up and running again.
@chrishamm I did some more testing, and I think I "might" have something.
I realized that prusa slicer is using
GET /rr_connect
but this call returns 404, I have a feeling this is not normal.I tried with
curl 'http://3d.e42.ch/rr_connect?password=1234' -v
and sure enough I get a 404.
Prusa seems to ignore the error and proceed to the rest of the requests (
/machine/status
...), which works if no password is set, but doesn't if it is set. -
@kuon It is normal. DSF v3.5 will get an emulation layer for
rr_
calls but DSF v3.4 only supports the REST HTTP API, see https://github.com/Duet3D/DuetSoftwareFramework/wiki/REST-API-(v3.4.4-or-newer) -
@kuon
apt
says I have the latest 3.4.4 version, but maybe the install got corrupted some way. -
@chrishamm Ok, I guess I'll reinstall my board, but I have one last question that didn't get answered. If a password is set, when reloading the browser, the password should NOT be prompted again right? (like a remember password thing)
@kuon Yes, it should be prompted. The password is stored per browser session and when you open a new tab or window, you create a different new session. It should not be prompted after E-STOP, though.
@chrishamm Ok, so I think I got the full understanding of the thing now:
- I expected the password to NOT be prompted again forever (or 30 days) (like remember password) with a cookie of some sort. This expectation was wrong, and I took the constant prompting on reload as a bug while it was the intended behavior.
- The password was only set on initial start and emergency shutdown, because it was set in
config.g
and notdsf-config.g
. This explains why I had to restart the service to "fix" this. - Prusa slicer just does not support authenticating with 3.4.4.
The only actual bug is that
dsf-config.g
is not executed. For this I checked the logs and I don't see mention of it, also the permissions are OK.For the actual issue, I guess I'll just not use the password feature of the rep rap and I'll use other mean to prevent accidental access (like creating a VLAN for the printer and the control computer).
@kuon I just checked, the reason why
dsf-config.g
isn't executed is probably because you didn't set up the plugin services (potentially with AppArmor) as described in the upgrade notes. It is already integrated in the latest image but just in case you want to have another look, here the upgrade notes again: https://github.com/Duet3D/DuetSoftwareFramework/wiki/Changelog-DSF-3.x#version-330Maybe @bot can help again with password support in SuperSlicer/PrusaSlicer (see here, here, and here)
