DWC clears print information at end of print - RRF3.4.4
At the end of a print, information such as the warm up time is cleared leaving only the total print time.
It would be helpful if this information was retained until the next print is started.Also, the warm-up time doesn't include anything thats ran from start.g so its not very easy to calculate the actual print time.
I have also seen the heater warm up time not included as part of warm-up timeI can confirm that tool heat up time is not included in warm-up time.At the moment i'm having to make note of the job duration time when the print actually starts and then subtracting it from the total job duration to get the actual print time.
I should also add i'm running in standalone mode on a duet 3 mini 5+
