    Conflicting Configurations
    Laser Cutters
    • kchristopherundefined
      kchristopher
      I am struggling trying to get my Co2 laser to respond to PWM commands. Unfortunately the documentation is conflicting so I am unsure which is correct or if I am doing something wrong.
      I have a Duet 3 mini 5+ and a 50W PSU for the laser.
      Per the documentation I have connected the laser GND, 5V and PWM wires to the appropriate pins on the Duet 3.
      https://docs.duet3d.com/User_manual/Reference/Gcodes#m452-select-laser-device-mode
      https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_laser
      50W PSU - https://www.amazon.com/dp/B0B38X19XS
      JoergS5undefined 1 Reply Last reply Reply Quote 0
      • JoergS5undefined
        JoergS5 @kchristopher
        @kchristopher it is unclear what you mean by conflicting. Do you mean the C setting? This is the pin name and you should use the one which matches the pin where you have connected the laser. The exp.... example is an example for a Duet 2 Duex board, if I remember correctly.
        To check your full configuration, please post your complete config.g, e. g. to check whether you have set the mentioned M563 setting in https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_laser
        kchristopherundefined 1 Reply Last reply Reply Quote 0
          kchristopher @JoergS5
          @JoergS5
          I slept on it overnight and I woke up with the with the solution. The problem was two fold I am going to post my solutions in another clean thread so others can use this information using this amazing board.
          • JoergS5undefined
            @kchristopher nice to hear that you solved it!
