    Confusion re DWC 'control heaters'
    Duet Web Control
    1.3k
    • jens55undefined
      jens55
      My apologies for being somewhat dense .... on the DWC screen, in the heater section, there is a button for 'control heaters'. If I click on that I get a new window. The very top has a button 'turn everything off'. If any heater is active or on standby, this button becomes available.
      In my thinking, if I click on that button, all heaters should turn off. In actuality, if I click that button, nothing seems to happen. The heater status of the active heater(s) is still active and temperature settings do not change.
      The DWC manual says "The Control All menu allows for all heaters to be turned off, as well as setting global active and standby temps" which suggests that I should be able to click on that button to turn all heaters off .... but they don't ..... ??????
      What am I missing here?
      Edit: I asked that question once before (May 2020) and got one reply where the poster confirmed the button doesn't seem to do anything.
      There was no official statement of 'we know it's broken' or 'it will be fixed real soon now'
      I am running DWC 3.4.0 so not the latest version ....
      Edit2: found another previous post of mine about the same issue. This one in in Oct 2021. While chrishamm responded, nothing was ever resolved and the issue remains (at least for me)
      Phaedruxundefined 1 Reply Last reply Reply Quote 1
      • achrnundefined
        achrn
        On mine (MB6HC, FW & DWC 3.4.2) if I don't fill in the 'set temperatures' slots, it switches all the heaters off (but leaves set points as they were).
        jens55undefined 1 Reply Last reply Reply Quote 0
        • jens55undefined
          jens55 @achrn
          @achrn, I tried that - set all extruder temperatures to 10C (active and standby), set the bed to 10C (active and standby) made the first extruder heater active and tried clicking on 'turn everything off'. Alas, nothing turned off.
          Interesting thought ... my hot ends are all on tool boards run via CAN and via a tool distribution board. I wonder if that affects anything. I also run a Duet 6HC main board.
          I did not have a tool loaded during my tests as that should not affect anything.
            Phaedrux Moderator @jens55
            @jens55 said in Confusion re DWC 'control heaters':
            Do you have a link to that thread?
            • jens55undefined
              jens55 @Phaedrux
              @Phaedrux, it was quite the search but here it is:
              https://forum.duet3d.com/topic/25386/dwc-3-4-0-beta4-troubles?_=1668498614804
              chrishammundefined 2 Replies Last reply Reply Quote 0
              • chrishammundefined
                chrishamm administrators @jens55
                @jens55 Please share your configuration and I'll try to reproduce it. I just attempted it again with v3.4.4 and it turns off the tool heaters and bed correctly.
                PS: I just realized you had it attached to one of your earlier posts. I'll try that one next.
                Duet software engineer
                  @jens55 Before "Turn everything off":
                  and after "Turn everything off":
                  Please confirm that this problem is actually still present with RRF and DWC 3.4.4.
                  • jens55undefined
                    jens55 @chrishamm
                    @chrishamm, I upgraded to 3.4.4, set tool 1 to active, set the bed to active (temperatures of each where 0), selected 'control heaters, selected 'turn everything off' and this is the result:
                    No change in heater status of either the tool or the bed 😞
                    Edit: heated the bed up to 65 degrees and tried 'turn off everything' again - neither the status (active) nor the active temperature changed.
                      Clear your browser cache?
                      • jens55undefined
                        jens55 @Phaedrux
                        @Phaedrux, how do I clear my browser cache in Firefox under Ubuntu?
                        BTW, I did reload the page just in case - I do not know if that counts as clearing the cache
                          https://support.mozilla.org/en-US/kb/how-clear-firefox-cache
                          • jens55undefined
                            jens55 @Phaedrux
                            @Phaedrux, no difference
                            • jens55undefined
                              jens55
                              Since I ran into other issues with the functionality of the 'control heaters' button where things didn't quite work the way I was expecting them to work, I am thinking that there is a good possibility that I am using that button wrong somehow. While I am certain that my way of effecting a shut off makes sense, there is no reason that the powers to be were thinking along the same lines.
                              So let me approach this from a different angle. Here are the steps I take when I try to shut down everything. Somebody please tell me if I am doing something wrong or if I am missing a step:
                              Let's say I just finished printing something and an extruder is active and the bed is active. I would like to turn everything off. Here are the steps I take:
                              I click on 'control heaters'
                              A small window opens up below the 'control heaters' button
                              At the top of this new window there is a big blue button that says 'turn everything off'
                              I click on that button, I see a slight flicker in the button which to me means my button press was recognized.
                              I do not click on anything else or do anything else - at this point and I expect all the heaters to go into the 'off' status.
                              If I click on the main window, the little sub window closes and I am still left with two active heaters.
                              Am I missing anything? Am I doing something wrong ?
                              Edit: I can select the radio buttons to either set tool temperature or bed temperature or both. I can the either enter (or select from a drop-down) the active temperature and/or the standby temperature. After having entered a temperature, as soon as I hit 'enter' then all active or standby temperatures for all heaters get set.
                              So this part seems to work the way it was meant to work.
                              • jens55undefined
                                jens55
                                bump for my last question in this thread
                                • jens55undefined
                                  jens55
                                  Folks, I could really use some assistance with this issue and it will take all but 30 seconds for you to go to the DWC for your printer, activating any one heater and then confirming the steps you take to de-activate this and any other heaters that might be active. Simply click on 'control heaters' and give me a list of everything you do or click in order to turn that heater off. So yes, writing down the steps you took in the 'control heaters' sub window to shut your heaters off might take another minute or two.
                                  Pretty please .... with icing sugar on it and a big fat cherry on top ....
                                    On my Duet wifi with 3.4.4 it works as expected. I don't currently have a SBC setup to test though.
                                    • jens55undefined
                                      jens55 @Phaedrux
                                      @Phaedrux, my setup is also a setup without an SBC. So if I may, I am trying to determine if I am doing something wrong in my operation and would like to know if the steps I have outlined above are the correct steps. So, if you have any heaters active or in standby, is the correct way to click on 'control heaters' and then click on 'turn everything off' or is there anything else that I am expected to do ? Will all heaters then switch status to 'off'? It all seems extremely straight forward but I manage to screw up a surprising amount of things that appear straight forward at first glance ....
                                      • jens55undefined
                                        jens55
                                        Is there maybe a setting in DWC that I must enable to allow the 'turn everything off' button to function?
                                        • jens55undefined
                                          jens55
                                          OK, this is getting really weird .... I have two printers that run Duet boards. One runs a Duet 2 wifi with a Duex board attached and it runs DWC 3.4.0. The second printer runs a Duet 6HC board with 4 tool boards. It runs Duet 3.4.4 and it is the printer that I have noticed this problem with.
                                          I just went through all the combinations of menus that display the heaters with the 6HC board printer - none of the possible menu combinations I tried did anything when hitting the 'turn everything off' button. Out of desperation and with nothing to loose, I looked at the printer running the Duet2 wifi ..... for some bizarre reason, the 'turn off everything' button works totally as expected !!!!! WTF ???? While the Duet2 does run 3.4.0, the Duet3 had the issue when 3.4.0 was installed on it!
                                          • jens55undefined
                                            jens55
                                            Yup, tried it again and yes, I press te button and everything turns off. Not only does everything turn off but the 'turn everything off' button that was blue before, changes to a non-blue version of itself. The Duet3 'turn everything off' button is blue but stays blue after it is clicked!
                                            On the Duet3, the 'turn everything off' button is blue only if a heater is active or in standby. This is the same as how the Duet2 system works.
                                            So .... is the inability of turning things off related to the 6HC board? Is it related to all heaters except the bed being run off tool boards? Is there something in config.g that needs to be set a particular way ?
                                            So, it would seem that the way I am trying to operate the 'turn everything off' button is actually correct.
                                            Let me rephrase my question based on the newly discovered info: If you have a Duet 6HC board, does your 'turn everything off' button work? Do you have your heaters running off the main board or are you using heaters that run via tool boards?
