    DIY a dispensing machine
    Laser Cutters
    505
    • NO1NOKAOundefined
      NO1NOKAO
      I want to DIY a dispensing machine, using PWM Fan0 to control the switch of the air pump. What do I need to write in the configuration file? The manual says to use the M950 to configure a tool. I would appreciate your providing specific examples or any detailed description.
      By the way, my control panel is Duet2 wifi and Duex5.
        Sounds like you want to use a combination of M950 to define the pin and M42 to switch it.
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m42-switch-io-pin
        https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m950-create-heater-fan-spindle-or-gpioservo-pin
        In config.g:
        M950 P0 C"fan0" ; create output port 0 attached to fan 0 pin
        In your control macro:
        M42 P0 S0 ; turn pin off
        or
        M42 P0 S1; turn pin on
        NO1NOKAOundefined 2 Replies Last reply Reply Quote 0
        • NO1NOKAOundefined
          NO1NOKAO @Phaedrux
          @Phaedrux Thanks bro,I'll read it carefully.
          • NO1NOKAOundefined
            NO1NOKAO @Phaedrux
            @Phaedrux And one more question by the way, does control macro means my G-code files?
              Phaedrux Moderator @NO1NOKAO
              @NO1NOKAO said in DIY a dispensing machine:
              It means where ever you want to activate the device from.
              NO1NOKAOundefined 1 Reply Last reply Reply Quote 0
              • NO1NOKAOundefined
                NO1NOKAO @Phaedrux
                @Phaedrux
                Thanks buddy, it really worked well.
                Now I'm facing another new problem that the pump-switching voltage does not match the panel-output-voltage. Because when I send G1 P0 S0 command, the control panel outputs 1.13V voltage and when I send P0 S1, it outputs 24V voltage. It's really difficult to adjust the voltage to 5V. Do you have any suggestions for that?
                Finally, please allow me to express my thanks once again.
                  What is your M670 command?
                    dc42 administrators @NO1NOKAO
                    @NO1NOKAO if the pump requires 5V switching voltage at low current then I suggest you use one of the five PWM outputs on the DueX board.
                    • NO1NOKAOundefined
                      NO1NOKAO @dc42
                      @dc42 If I use a duex5 expension board, should I make some definition in config.g file to make sure both of the duet2 wifi and duex5 are enabled? I mean that changing the C parament of M950 command is needed and what else?
                        @NO1NOKAO the DueX will be enabled automatically when the firmware on the Duet detects it. If you send M115 then the response should mention the DueX.
